Safe boost level stock LS1
What is a realistic boost level that is safe with the following: 42#injectors, racetronix plug and play, FMIC, throttle body coolant bypass, 160 thermostat, STS 67. Going to run it around 11.2 to 1 A/F. Car is a 2001 SS with a M6. I just want a good street machine, with a good dyno tune, conservative all around, not into rebuilding engine at this time. Have the blue and green wastegate springs (Tial wastegate) and I'd like to go more than the 5psi spring (red). Had the injectors flowed and at 58psi they all are pretty close to 47 psi, put the richest one in #7 hole.
Thanks
Thanks
Restricted User
Originally Posted by Slowhawk
More boost=more stress.
We run 8-10lbs with intercoolers and a good tune. On my personal Vette I ran 14lbs on the stock motor but didn't drive it hard alot on the street.Car has 10k miles on it.
jus think of better to be safe than sorry...as with all things in this case (turbocharged LS1's) lol
10 is a bit high, depending on the weather and octane. 8.5-9 I've run for 4 years, and about 30K miles.
now its got a tick, think a wrist pin, the pistons are fine. swapped to lq9 heads a year ago, and was hoping it was a lifter.
new motor is in the works.
