Testing a Fast 90 or LS6 vs Victor with FI
Old 03-26-2006, 11:43 AM
CHarris's Avatar
Default Testing a Fast 90 or LS6 vs Victor with FI
Has anyone done a dyno with a LS6 or Fast 90 FI setup against a Victor?
Any before and after numbers? I've serached the dyno section and the FI section and come up with nada. I know the benefits of the Victor vs the others... but what were the numbers?
Thanks to anyone who can share experience!
Also was there a drop in IAT's (or any way to measure it)?
Old 03-26-2006, 12:08 PM
cablebandit's Avatar
i'd like to know as well from a FI standpoint
Old 03-26-2006, 01:36 PM
TT-TECH Veteran
Inspector12's Avatar
All the info I have read says that up to 10-12bls of boost not a lot of difference in any, but as the boost rises 15+ lbs the Victor jr starts to shine. Most of the info I've seen has been in magazines. There was a guy here on the board that did back to back pulls with a LS6 and a Fast 90/90 set up and he lost @20rwhp and 18lbs of tq with the Fast, but that was with only 8-10 lbs of boost that was a while back when they first cam out I don't know the exact details of his set up I am just passing on what little info I have read and definatly not from personal experience as of yet.
Old 03-26-2006, 01:53 PM
LS1Tech Sponsor
Slowhawk's Avatar
408ci T88
LS6 against Victor at 14lbs
The victor runs alot smoother under boost,Intake temps dropped 25+ degree's,gained 60hp/60tq in the midrange,pretty much the same peak #'s because the Turbo held the same boost level. A Supercharged car will probly make more HP due to boost increase.
Old 03-26-2006, 04:27 PM
CHarris's Avatar
Thanks for dropping some info in this thread Slowhawk and Inspector 12! I knew it was out there somewhere!
Anyone else got some info to share?
Thanks!
Old 03-26-2006, 08:04 PM
Wet 1's Avatar
Originally Posted by Slowhawk
408ci T88
The victor runs alot smoother under boost,Intake temps dropped 25+ degree's...
Don, why did/would the intake temps change going from one to the other? I'm half asleep, but I can't see why that would change. What am I missing?
Old 03-26-2006, 08:45 PM
CHarris's Avatar
I'm assuming less friction from airflow and compression (from building boost)?
Old 03-26-2006, 09:57 PM
LS1Tech Sponsor
Slowhawk's Avatar
I'm figuring efficiency. The rear cylinder's have more heat from running leaner than the rest/pass it to the Turbo/heat goes to inlet side of turbo/through the intercooler? Either way that is the info I got from scaning the different setup's on very close day temps. I just know it worked good
Old 03-26-2006, 10:06 PM
JMBLOWNWS6's Avatar
Dam man. I want to switch my setup and I havent even started the car.
Old 03-27-2006, 08:25 AM
Wet 1's Avatar
Hmmm, I slept on it and I'm still not sure I'd buy into the temp drop... I wonder if there was another reason for the change or if it was just an fluke?
Regardless, it sounds like the way to go for FI. 60/60 is pretty damn impressive in the mid range (like it needed it!), what happened on the bottom end? I assume there was a little drop? Any down sides to going this route?
BTW, how tall is this intake w/o the elbow compared to say an LS6? How much of a bump in the hood would you need to fit this thing in a C5?
Thanks again Don for your input!
Old 03-27-2006, 08:47 AM
PurEvl's Avatar
well its documented that the victor intake is supposed to help with the dreaded number 7 an 8 pistons so who knows...but both days where in the 40-50's and nothin changed.
And in all honesty, i didnt notice anything different down low...i did notice it comes in alot smooth and also the boost was instant in 3rd gear...actually too quick as it surprised the **** out of me.
Old 03-27-2006, 09:40 AM
LSONE's Avatar
GMHTP reported a 90hp gain on a supercharged car a few months ago.
Old 03-27-2006, 09:41 AM
Wet 1's Avatar
I'd think there would be a small hit down low, but who really cares about that? What does surprise me is that you really didn't gain much on the top end... I expected there would be a little bumb in the mid range power, but I expected to see most of the benefit above 5500 rpm.
Would you guys mind posting a couple dyno charts to compare the two (assuming no other changes were made and they were run with comparable tunes)? I'm sure people would like to see these results going forward.
Thanks again guys!
Old 03-27-2006, 10:34 AM
PurEvl's Avatar
i dont have the graphs, dont really care since its not even tuned with the 2 bar thats going in next week or so. Its going for 16psi for street tune, if Don actually has the graphs then its up to him. I dont care what its doing right now to tell the truth since its not the final setup
Old 03-27-2006, 11:05 AM
Wet 1's Avatar
No big deal, I just made the suggestion so others who are thinking about changing over the intakes have some good data to compare.
Keep us posted with your updates next week!
Old 03-27-2006, 11:53 AM
stevieturbo's Avatar
408ci T88
Why would the boost increase ? Surely if the manifold is free-er flowing the boost would drop ??
Or do you mean if you re-pullied for same boost as Lsx intake it would make more power ?
Old 03-27-2006, 04:22 PM
LS1Tech Sponsor
Slowhawk's Avatar
Thanks again guys!
The Turbo provides boost by manifold pressure-not a belt drive.So when you have 14lbs dialed in it doesn't matter what restrictions you have,the Turbo will adjust to it's setting.
With the 408 motor there was no hit at all.Maybe a smaller ci will see it.But the 4.8L I just put one on feels just as strong as the stock truck intake down low We very rarely print out Mike's runs.No reason too since we keep changing things
Old 03-27-2006, 04:25 PM
LS1Tech Sponsor
Slowhawk's Avatar
i shouldn't say boost increase,should say HP increase with the possibility of less boost pressure. We had a car 2 years ago that made 1 pound of boost but gained 100rwhp more than stock. Kind off weird but efficient
