can i get away with this?
7 Second Club
i'll be running about 11.0:1 CR with a D1 only running about 8-10 lbs of boost this season until winter then i figure ill swap to a deeper dish piston and larger CC combustion chamber...
but for the time being can i run 93 gas on a D1 with about 10lbs max with 11:1 CR....
i might even get a drum of 104 and mix 1 gallon per tank to be safe if you think it will be work my time.
I'll probably turn my direct port kit into a wet single nozzle and spray a 50 or 100 shot with c14...
TIA
TIA
You can if you use straight C16, that could get a little expensive though
With a good intercooler I would stay at 7-8lbs or so with pump gas IF you have forged pistons. I would run straight 104 with 10psi. Lot of factors involved but you are asking for trouble at 10psi with pump gas..
7 Second Club
arent there d1 kits for the ls2 cars? i thought they were 10.9 CR ?
well fudge... it may look like new pistons are on the way
i wish i could have made up my mind about 4 months ago
7 Second Club
Originally Posted by kp
This is on the new 408? If its not in the car yet why not just do the pistons..
yeah.. new 408... thats what im saying ill just go ahead and splurge a little more and grab some pistons
thats all this game is isnt it.... just spending money
