How can I lower the compression on my Cartek S2 heads for FI?
If you open your quench (squish) area too much, you'll end up with worse detonation than if you left it alone. You can't go much above .055", maybe .060", and .040" is optimal.
I would call Cartek and see if there is enough material for them to enlarge the chambers at all. That's about your only option for physically changing the CR without touching the bottom end (dished pistons).
Jim
Jim
Simplified answer from one who has seen many "Exploding engines" lol
Ok so JE,SRP make pistons specific for FI/power adders...Go with whats proven by the big guys,,,,,Sure you can find some cheapies on ebay...
But the "Big guys" spend millions on r&d.......
And actually you can effectively lower the c/r by about 1 point max with a "huge" mls cometic type gasket....But if you do make sure that you use longer headbolts
torqued in the correct ft/lb and in the correct sequence.......
Run the car check for leaks allow it run till operating temp,,,,
Allow it too cool down and double check if the torque# is correct
And actual water/meth sprayers work excellently......Keep the egts down...
lower detonation etc....Dont screw around and max out the timing for max hp
Thats when you blow snit up.......
Sonny G<
