F/I Crew, Who has knowledge of broken comp 918 spring with less than .590 lift?
Thinking this will probably be my spring, comp 918s, to upgrade the stockers on my stock BLOWN LS6 motor in my 02 Z06.
If you broke one or have knowledge of someone breaking one, what were the cam specs, etc., and how long ago did this happen!
THANKS GUYS!!!!!!
THANKS GUYS!!!!!!
The same 918s have been in my car for 2 years with 2 cams The 1st cam which I ran NA was .575 lift shifting at 6400 & the new one is .569. It's been FI with the new cam since 3/1/06. 3 days at the track so far this year. It's an M6 & I hit the rev limiter (6700) every shift. No problems with the valve train so far.
I've broken ONE 918 with over 30k on 'em... Pre-blue stripe ones too, you know, the ones that "always" broke? I've run them with 5 different cams, from 571 lift up to 609 lift. They're currently on top of a 238/240 .605/.609 112+2 XE-R, but I'll admit I need more spring.
We use the 918's on our LS1 and Viper motors, both N/A and turbo set-ups with very good results. I don't know of any broken springs in the last 3 years, and we do a lot of cylinder heads and complete engine builds.
The million dollar question is that although i know the 918s are a great single spring and make A TON of sense for my application, i REALLY prefer the safety net of the second spring offered on the Patriot dual golds and want to run a DUAL spring, but on a stock BLOWN LS6 motor, is the Patriot dual golds too much spring, that will screw something up on my set-up which has proven to be reliable after 3400 miles!!
Originally Posted by RICE ETR
24K miles on my 918's with the TR cam 227/224 ~.570" cam, 20K has been under boost.
Originally Posted by foshizl
so would you just run like the slp timing chain set with the duals? or would you go to double roller timing chain
1 Post
With a TR224 .563 112LSA cam I ran the engine to 6750RPM's at the track on at least 40 1/4 mile runs. Added to this another 5 or so passes to 6250 with the cam AND the turbo set to 5PSI. Springs have 5K miles on them and are daily driven. No problems yet.
I had one break on .578 lift cam the day I was driving to Lubbock to get it tuned. I wouldn't worry about it though, I think I just wound up with a faulty spring from te factory. I had it replaced and I haven't had any problems since. My car isn't boosted yet though.
