CAS twin turbo causing bad vibration???
when i drive my car i can feel a strong vibration coming through the steering wheel and the shifter. i did noticed the passenger side turbo is smack against the body of the car and it is resting on the stock K memeber. also the driver side wastegate is resting on the K member. could this be causing the vibration? other than that the car fires right up, oil pressure good and drives normal (for a untuned car).
i thought the CAS kit was suppost to fit the stock K member?
