? about putting a little spray on top of a blower car.
Old 04-25-2006, 12:25 PM
Raced Guy's Avatar
Default ? about putting a little spray on top of a blower car.
I have a C5 with a D1SC at 9psi, tunned very rich at 10.5 degrees of timing at wot,60lb injectors,kb bap, and was thinking of putting a 50 shot on it just to help it out down low. Should it be okay?
Old 04-25-2006, 08:29 PM
Raced Guy's Avatar
Hmmmm, anyone ???
Old 04-25-2006, 08:39 PM
kp
kp's Avatar
I ran a 50 dry shot on a P1SC car but I had the MAF recalibrated where it would read at 8psi + the 50 shot and it worked very well. 1/2 a second and 5mph in the 1/4 or so. Putting a 50-75 wet shot on it should be no problem as long as your fuel system will keep up. I would be very careful and keep it rich if you have stock pistons though..
Old 04-25-2006, 08:45 PM
brad8266's Avatar
10.5 timing is a bitt much retard dont ya think?? Anyway a small shot helps a lot and it really cools down the charged air.
Old 04-25-2006, 11:42 PM
DeltaT's Avatar
Jeez, I'm running 7.5# at 24 degrees advance and 12.2 AFR. Yours seems too conservative, unless you are knocking all the time. My CR is 9.66:1.
Like brad said... but I think you should get a better tune before you add it. That is what I would call a lazy shop tune - make it work, make it safe, but no optimization.
If you add a shot, think about a MSD retard box that only is active when you are spraying. I use the MSD Multi-Step Retard tied to the NOS solenoids. I like to stick with the NOS recommendation of 2 degrees pulled out for every 50HP in nitrous. AFR target on spray of about 11.5:1.
Jim
My Site: http://home.mindspring.com/~jim_fisk/id1.html
Old 04-25-2006, 11:46 PM
kp
kp's Avatar
I assumed he meant a rich 10.5 a/f not timing
A 50 shot wouldnt help much with 10 degrees of timing
Old 04-26-2006, 04:29 PM
DeltaT's Avatar
Either would explain his sagging bottom end!
Jim
Old 04-26-2006, 07:19 PM
7 Second Club
BlwnTA's Avatar
SEE SIGNATURE...no problem here.
Old 04-27-2006, 06:41 AM
EPP
EPP's Avatar
Smile
Depending on what octane you have available, you should have no problems running 18 to 22 degrees of timing at wide open throttle, with no spark knock. This in itself would wake up your car. We set C5's up all the time with the timing in this range. Bob
Old 04-27-2006, 04:03 PM
TS6
TS6's Avatar
Wow, thats alot through a stock maf! I didn't think you could do that. I'll actually have an identical setup, but was going to go wet nitrous. Maybe I'll rethink it.....
Old 04-28-2006, 04:19 PM
Raced Guy's Avatar
I had the scan tool hooked up and at wot the timing was at 10.5 degres, yes they tunned it safe and yes im am not to happy when i found that out, safe is one thing, choking it out is another. It is kind of laggy down low and that is why i wanted to do this.
Old 04-28-2006, 08:23 PM
muncie21's Avatar
My SC'd C5 runs around 15* at WOT on the top end. 11.2-11.5 AFR. Tried 10.5 AFR and it killed like 20 ft/lbs on the dyno
Old 05-01-2006, 07:09 PM
Raced Guy's Avatar
So can i just tune it to say 15 deg. at wot and not have to play with the fuel curves, because i can get that done. I dont want to pay another $180 for throwing it on the dyno.
Old 05-01-2006, 07:29 PM
muncie21's Avatar
You don't have to worry about 'fuel curves' if all you are concerned about is WOT. If that's the case, dial in a sane (11-12) AFR and make sure you don't have any KR. Even then, I'd recommend you check it on a dyno. When I first dyno'd my car my commanded AFR was 12.1x, but my actual AFR was 13.6x. Not good
My opinion? Spend the money and get a good tune. Unless you add more parts, the tune won't go 'bad'.
Old 05-01-2006, 08:15 PM
Raced Guy's Avatar
It already has a good tune mius the timing issue, it was on the dyno for about 2 hours getting pretty damn good and safe, just want more timing so i can wake it up a tad where its lazy.
Old 05-01-2006, 09:05 PM
muncie21's Avatar
For the timing, you need to find out what it's running versus the commanded timing. If you are running less than commanded then something's pulling timing on you (heat, KR, etc). If everything is fine, bump your WOT timing in increments of 2* until you see knock, and then back off.
Old 05-01-2006, 09:27 PM
markp03's Avatar
racd guy where do you live? and what color is your car ? =)
Old 05-02-2006, 12:43 AM
mahhddgtp's Avatar
With that AFR, you should be able to add a lot more timing, I'd think. If you have a Scanmaster or a knock sensor setup to tell you when you're getting nasty knock on the spot, just go up in timing in increments of 2.
Old 05-02-2006, 03:52 PM
Raced Guy's Avatar
Mark you know, its Ryan with the peweter C5
