MAP Sensor Location
The stock map only reads up to 0 kpa. So when you are in boost mode (above 0 kpa) you will start to run lean. With a 2bar map, and a correct tune, you can add fuel in the boosted areas to improve performance.
Originally Posted by MiaSSmaro98
so then were can u get a 2 bar map?
