Ceramic coating vs. Exhaust wrap?
Well I can tell you to jet-hot a set of turbo headers it will be about $300, turbo housings are around 75 each when I got my quote for 2000+deg
I'm going to be using header wrap because I'm making new 304 headers so no point in coating my current ones right now.
I've heard that header wraps trap in moisture and make the pipes rust really fast. I have no direct experience.
Thats also another reason I am making 304 headers from some of the research I've done ceramic on 304 is pointless - it would be nice to hear from someone that knows how much of a difference there really is
course mild rust anyways, dont know the difference on how fast one rusts wrapped to unwrappped.
Evidently....
Originally Posted by smokinHawk
on stainless no, mild yes.
The wrap holds the heat in the tubing, and can concentrate it to a point that the materials are affected in a negative way...
As for ceramic on stainless... WHY NOT? The idea of the stainless is to better stand the elevated temps, especially that of an FI engine. The coating holds the heat rejection down, and lowers the under hood temps by a significant amt.
The results?? The best of both worlds, so to speak. More durable headers, and less heat in the under hood area.
As for the wrap... It makes a great wick, when oil soaked.
Originally Posted by Country Boy
Anyone have experience which would work keeping the heat in the pipes better and not in the engine bay?
get it in get it running get it wrapped...
then later on in life id get them coated..but get it on and all worked out id do that...
onec you do your first intalll tske the tti street kit apart and back in is easy!
well i would get the headers coated inside and our! thsi reduce the heat stress on the stainless and reduces under hood temps! then heat wrap just to be safe and to reduce temps even further! then you could even add a heat shield!
thansk chris
PS anyone multi layer the ceramic coarings???? i have heard of it being done!
thansk chris
Senior Member
Id rather not have to take it all back apart again. This is my only car too. I have another one I could drive, but its a PITA since its my work truck. I dont want the couple week down time
Senior Member
thansk chris
thansk chris
I wouldnt get the inside coated. I wouldnt want to risk it flaking and send stuff into the turbine....
How much mositure can the wrap hold? Wouldnt it all burn off when you drive it? I didnt like the oil and wick comment though.. LOL
Country Boy, as long as you get the costings done profetionaly at a shop the does all the right prep work then you will be fine!
and the internal coating really helps! it smooths out imperfections and drematicaly reduces the thermal stress on the header itselfs (heat has to go through the coating before even getting to the metal)! and just doing an external coat will lead to even great thermal load on the headers as there is no where for the heat to go!
thanks Chris.
thanks Chris.
Originally Posted by GTFORMULA
I was wondering if coating with ceramic on mild steel then wrapping it would be a good combo ? The coating would keep it from rusting right ?
