Throwing Belt!
Old 04-29-2006, 11:33 AM
02' hawk's Avatar
Default Throwing Belt!
My D-1SC procharger is throwing the belt in the higher rpm's (6500). My question is how do i get it lined back up to the crank?
Old 04-29-2006, 11:37 AM
LS1Tech Sponsor
Slowhawk's Avatar
Either the belt isn't tight enough or you have to align it. Use a straight edge or laser alignment with the belt tight.
Old 04-29-2006, 11:47 AM
EPP
EPP's Avatar
The blower belt has to be much tighter than what you would expect it to. I would first try tightening it up. Bob
Old 04-29-2006, 03:02 PM
frcefed98's Avatar
Good rule of thumb with the s/c belt and how tight it needs to be is...tighten it so you can pluck it like a guitar string and get a good tone out of it.
OR just get the SDCE 8 rib set up and you'll be good. Do it now and save yourself a lot of hassle....if you don't already have it
Old 04-29-2006, 04:41 PM
b727pic's Avatar
Does the belt tend to ride up against the front or back of the blower pulley????
I had some trouble with my initial install, Bob, Brent and Guys at EPP were alot of help, wound up having to install a fluidampr which ultimately resolved my issue. However still had some initial issues. The final solution which worked for me....... I backed off the blower pulley bolt about 3/8ths of an inch, started the car and let it idle for a few seconds, the belt will true itself out and track where it wants to. At this point measure the gap if any between the pulley and the blower and install / remove spacers as needed. I have not had any issues since....
Old 04-29-2006, 08:00 PM
02' hawk's Avatar
[QUOTE=b727pic]Does the belt tend to ride up against the front or back of the blower pulley????
The back of that pulley and the front of the crank pulley!
Old 04-30-2006, 12:37 AM
b727pic's Avatar
[QUOTE=02' hawk]
is there a spacer in back of the blower pulley??
if so try removing that spacer.....
I am familiar with the GTO install, afraid I can't offer much more advice other than to give EPP a call for some help......good guys, know this procharger stuff inside and out.....good luck
Old 04-30-2006, 10:59 AM
02' hawk's Avatar
[QUOTE=b727pic][QUOTE=02' hawk]
I think there was when i put the other pulley on. I didn't even think about that idea!
Quick Reply: Throwing Belt!
