F1-R Owners ... please chime in.
Old 04-30-2006, 06:04 AM
Gold Phoenix's Avatar
Default F1-R Owners ... please chime in.
In less than two months, I will have my new powertrain installed in my F-body. What I would like to see is everyone that has a F1-R setup, what mods your have, power output and/or laptimes. I am trying to get an idea what I will be making. Also, let me know if you had any failures or issues.
Old 04-30-2006, 09:33 AM
97F1R408's Avatar
It wont be a problem and Im sure you know the size of the injectors and fuel system needed.
Old 04-30-2006, 02:19 PM
I have my setup and all my bases are covered. I am curious about other F1-R setups and what kind of power they are putting out. I would also like to know how much boost they are seeing at about 6000rpms.
Old 04-30-2006, 04:36 PM
Bryan Wilkinson's Avatar
All depends on the CR you are running. Getting that HP number is a no brainer with that blower. I ran mine on 93 oct, but ran entirely too much boost on one run and blew it up. 18PSI at 10:1CR is where the C5-R block gave it up.
Old 04-30-2006, 07:39 PM
2000zrocks's Avatar
theres a guy here in green bay wi with a 2000 ss with the slp heads and cam package (im not sure which one) making 550 whp with an f1
Old 04-30-2006, 08:06 PM
EPP
EPP's Avatar
Question
http://www.exoticperformanceplus.com...Car.php?car=27
Geez, we made 717 rwhp with a 346 cid on my Mustang Chassis Dyno at 5200 rpm, with too mild of a camshaft. An F1R can easily either shoot your rwhp towards 900+rwhp or cause you to have to buy another block. Bob
Old 04-30-2006, 08:12 PM
LS1Tech Sponsor
Slowhawk's Avatar
For a pump gas/street car run the F1C,not the R. It will make the power.
Old 04-30-2006, 09:03 PM
97F1R408's Avatar
I disagree you will already be spending the same money for the big blower and the main difference in the R and the C is the step up ratio 5:1 the R kicks in way sooner and has more flow on top so you could always get it with a bigger pulley and have more for future addictions. As for the 2000 ss that made 550 rwhp somethings wrong you could get that out of a stock engine with a p-1.
Old 04-30-2006, 09:36 PM
Biggy's Avatar
I had Lt1 with F-1 Procharger on it pushing 16 pounds of boots on a 383 and on the dyno hit 765 rwhp. If that gives you an idea. If you are wanting to see 800 on pump gas hope you have a good tuner and low compression like 8 to one. Oh ya using 112 octane as fuel.
Old 04-30-2006, 09:42 PM
LS1Tech Sponsor
Slowhawk's Avatar
Then you know the output temp is alot hotter on a R series which makes it hard to cool on the street The F1R is pretty much a F2 with a small housing.
Old 04-30-2006, 11:50 PM
andereck's Avatar
As a rule a larger volute will give you a cooler outlet temp under boost.
The F1R is pretty much an F1R. The impellers are different between the F2 and F1R. Cruising outlet temp is a non-issue and neither blowers run hot at cruise. All shipping F1-F2 standard rotation blower variants run a 5.40 ratio now. The only exception are the NMRA models to fit their archaic rules. That should change next year.
The F1C is there to provide race blower performance but not terribly overboost a near stock shortblock. Mod motor Ford to LS2. All I've seen are reverse mount. C=cutdown impeller and as mentioned is good for a streetcar.
Old 05-01-2006, 08:26 AM
7 Second Club
ty_ty13's Avatar
i hope you realize slowhawk has alot of experience
Old 05-01-2006, 09:12 AM
PurEvl's Avatar
Originally Posted by ty_ty13
i hope you realize slowhawk has put of this **** together than you've ever seen and dynoed them more than you...
dont bother, what would he know..hes only put a few hundred FI cars together an logged about every blower known to man.
Slowhawk needs to read more blower brochures and use more math/theories. No one wants real world data...come on now
Old 05-01-2006, 09:15 AM
7 Second Club
ty_ty13's Avatar
sarcasim is getting thick in here
Old 05-01-2006, 10:46 AM
97F1R408's Avatar
TT_TY13 I hope you realize a couple of things as well, never did I question slowhawks abilitys or knowledge on anything. I know absolutely nothing about him as you know NOTHING about me, it was mearly an opinion (which everyone is entiltled to) And second one thing for sure I dont care what blower or car you have from supercharged turboed or nitrous Ive got something that will shut your mouth and thats not sarcasm or B.S. try me
Old 05-01-2006, 10:56 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Flag down.
Settle down.
Old 05-01-2006, 12:36 PM
TrakDay's Avatar
I personally just received my F1C blower for my new 408 blower setup going in my GTO. Its going to take some banging/cutting to make it fit, but I think it will be a much more fun blower on the street than the R. But who knows! And sorry to say but I won't have numbers for atleast a month or two.
Old 05-01-2006, 04:15 PM
777's Avatar
John, you do realize that you just posted twice saying basically the same things post *****
