blower brackets??
Old 05-09-2006, 06:01 PM
joshs02ss's Avatar
Default blower brackets??
i have 02 camaro, i am going to be running a d-1sc with double digit boost numbers. every thing i have been reading says i need to invest in a beefy blower mounting bracket. Does any body know where or who to talk to about getting one? i dont have many sources!!!!! thanks Josh b
Old 05-09-2006, 10:14 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Are you talking about the SDCE spring tensioner or the true tech steel bracket? I run both and they get the job done.
http://www.sd-concepts.com/cart/inde...products_id=19
http://truetechperformance.com/page/...rformance.html
Old 05-10-2006, 01:59 AM
joshs02ss's Avatar
what does the sdce spring tensioner acutal do i looked at it on line couldnt tell what it was????
Old 05-10-2006, 04:50 AM
EPP
EPP's Avatar
We have used the stock ProCharger bracket assembly at 14 to 16 psi of boost without seeing slippage when we ditch the inlet hat from the ProCharger assembly, and use an aluminum 4.00" elbow and a larger air filter. The stock inlet hat is a big restriction on the LS1 F Body cars. Bob
Old 05-10-2006, 11:01 PM
SVC707's Avatar
ill be getting this aluminum elbow and larger air filter with the kit i ordered correct. i was concerned about if i have to get new brackets too.
Old 05-10-2006, 11:19 PM
69firebird's Avatar
how much is the bracket it doesnt list a price.
that would also work for a F1 wouldnt it
thanks
ed
Old 05-11-2006, 04:39 AM
EPP
EPP's Avatar
Question
No, not unless you requested it. If you ordered the ATI ProCharger and deleted the intercoolers and their plumbing, and ordered our front mount intercooler kit, it is still going to come with the standard air inlet hat and the standard ATI ProCharger air filter assembly. Bob
Old 05-11-2006, 07:27 AM
thanks
ed
The true tech bracket was about 180.00 shipped.
Quick Reply: blower brackets??
