AFR 225 or AFR 205
Old 05-13-2006, 05:56 PM
NAVY's Avatar
Default AFR 225 or AFR 205
Hi i want to ask what is the best head AFR 225 or AFR 205 for ( VORTECH 12+ psi) .
thank you
navy
Old 05-13-2006, 07:19 PM
mdhmi's Avatar
205's unless you're doing a 4'' stroke.
Mark
Old 05-13-2006, 07:25 PM
InconFormula's Avatar
On a current customer car were working on AFR recommended the 225's for a forced induction application even on a stock cube motor.
Old 05-13-2006, 07:27 PM
Boo"SS"t's Avatar
I had the same question before I bought my 225cc's for my forged 347/CAS twin turbo combo. I called AFR and they recommended to go with 225cc's, at first i was kind'a concern about the 225's being a little too big for a 347", I just didn't want my car to be a real pig in the low rpm's, you know. but they said that as soon as i see 1# of boost with the bigger heads...i'tll just scream (i sure hope so! ). According to them, the window of time BEFORE it hits boost is so little compare to when i start making boost and on up, and what little i would loose in the low rpm's, i would gain a heck of lot more in the upper rpm's compare to a 205cc's... therefore more power. But, I'll find out soon for sure if i'll hit the power that i'm hoping for.
Old 05-13-2006, 08:59 PM
NAVY's Avatar
so my Engine 378ci with( VORTECH V1 T RACE M ) 12+ psi
Old 05-13-2006, 09:20 PM
Tiago's Avatar
Im running 225s on stock cubes, results in about 1 week ....
Old 05-13-2006, 10:22 PM
618HAWK's Avatar
Take a look at the 225 small chamber they look to be a better choice than the standard 225,s for the stock blown block.
Old 05-13-2006, 10:27 PM
NAVY's Avatar
ok after 1 week what a results Tiago ??
so AFR Mongoose 225cc FULLY CNC 72cc Chambers COMPLETE it a good choice .
Old 05-13-2006, 10:42 PM
7 Second Club
NicD's Avatar
225s all the way on a forced induction car. Velocity is most important on an N/A motor, you just want big heads for an F/I car in general.
Mine made 680 rwhp on 10 psi/91 octane on a low compression 347 with a 230/224 cam and AFR 225s. Not incredible, but expected given the good stout combo.
Old 05-13-2006, 11:57 PM
RW99's Avatar
Results on my AFR 225's in about a week, too.
Front mount T67, forged 347.
Old 05-14-2006, 09:33 AM
Wet 1's Avatar
225's without a doubt for FI!
Old 05-14-2006, 12:25 PM
mdhmi's Avatar
I respectfully disagree. There are stock cube C5's cars running 140-145 MPH with out of the box 205's. I went with the 205's for additional power under the curve and partial throttle acceleration. If I were doing a 4'' stroke I would have opted for the 225's.
Mark
Old 05-14-2006, 04:04 PM
Wet 1's Avatar
Mark
Okay, good luck with your 205's.
BTW just think, those cars running 140-145 mph could be running a little faster with the 225's.
Old 05-14-2006, 05:55 PM
mdhmi's Avatar
If I were building a ballz out race machine I would do the 225's. For a street machine I think the 205's offer greater value for stock cubes.
Mark
Old 05-14-2006, 06:06 PM
Tiago's Avatar
how is it a greater value the price is pretty much the same.
I guess I'll see how good it runs next weekend
Old 05-14-2006, 07:09 PM
mdhmi's Avatar
Greater value for my needs in the sense of partial throttle acceleration. I'm sure either head would meet your needs.
Mark
Old 05-15-2006, 12:00 PM
MTBDOC's Avatar
What is that?
Old 05-15-2006, 12:20 PM
mdhmi's Avatar
Originally Posted by MTBDOC
What is that?
The result of sufficient port velocity.
Mark
Old 05-16-2006, 01:40 AM
robb4964's Avatar
Not incredible? ..LOL..I disagree...
Old 05-24-2006, 11:08 PM
A DEE O's Avatar
Any results from the head swap?
Quick Reply: AFR 225 or AFR 205
