Hp/Tq #'s From Truck Mani Setups??
Wondering if you truck mani guys could chime in with #'s youre seeing on a stock block, preferably @ 5-6lbs and 8-9lbs of boost. Im going to be doing a single setup on stock block/internals for now w/prob 42lb injectors, am I am just curious as to what I might see.
Also, I was reading farily recently where someone w/a twin setup(non truck mani I think) had the a/c relocated or w/e. How doable would it be to relocate the a/c on a single truck mani setup??
Well since stock shortblocks are good to about 550rwhp before the ring lands eventually fail.... that would be a good target.
Also 42lbrs will limit you to around 550rwhp anyway.
Why not put in some forged pistons, buget Eagle rods, stock crank, stock 6.0 heads and make 600-700rwhp+ with stock LS6 intake/TB safely.
i have 6.0 manis and 6.0 heads mildly ported 290.intake 186.exhaust with a small cam 214 218 564. 546. on a 115 and on 8 psi i did 547 rwh with no methonal...so will see what happens on meth...im sure its time for the new short block, once i start driving the car hard!
