How many larger turbo (80+mm) street cars?
Old 05-27-2006, 12:30 AM
LS1Tech Co-Founder
Nine Ball's Avatar
Question How many larger turbo (80+mm) street cars?
Just curious, but how many of you guys are running 80mm or larger turbo setups on full street cars, including air conditioning and power steering?
I'm very tempted to put the 88mm turbo and 408ci I was planning on putting in the racecar into the new WS6 Formula I picked up. But, I want to keep this car 100% streetable.
Anyone do this with a stock K-member or without having to hack up the car?
Tony
Old 05-27-2006, 12:41 AM
Spdmini's Avatar
I have a BMR tubular K, 402, and baby T6 footprint Borg Warner 88mm. I have a/c and PS.
Old 05-27-2006, 12:57 AM
LS1Tech Co-Founder
Nine Ball's Avatar
Any pics? What size down pipe and where did you place the turbo?
Old 05-27-2006, 01:20 AM
Spdmini's Avatar
Its all in progress right now. the DP will be a 5inch down to 4inch out. the turbo is similar in size to a gt47. It will go in front of the dampener.
Old 05-27-2006, 02:40 AM
SSU Moderator
RyanJ's Avatar
where the hell are you putting a 4" dp w/ all the accessories...below the K? in the fender?
Old 05-27-2006, 03:22 AM
BLk01SS's Avatar
Tony just do a simplel setup in the Formula. You sold the other one I assume to keep from spending loads of money on race parts. Just do a Procharger or nice street turbo setup and roll with that. It would be a sweet car man!!!
Old 05-27-2006, 06:34 AM
Administrator
unit213's Avatar
Don't mess around with that WS6 Tony. It's too perfect to heavily modify like that
IMO. Running a 408 and a 88mm turbo = racecar...at least all the supporting
mods will make it feel like a racecar, even if it's driven on the street. A 67 or a 76
might be a different story.
Old 05-27-2006, 06:53 AM
JMBLOWNWS6's Avatar
We are starting on my buddies car. Its the one off kit from the sponsor that I cant talk about due to non payment. But his rad support is getting cut for the custom griffin radiator. 402(iron) with the T 88. Heres a pic of the turbo. A guy in town has the same turbo in his stang and it does 8's
http://i76.photobucket.com/albums/j1...1/DSCF0053.jpg
Old 05-27-2006, 08:26 AM
Tiago's Avatar
Tony
PTK
Old 05-27-2006, 08:36 AM
LS1Tech Co-Founder
Nine Ball's Avatar
I sold the other one because it was no longer a street car. Racing brakes, powerglide with t-brake, spool, drag wheels/tires only, 10-pt cage next to my head, no A/C or power steering.
besides, I already have all the engine, fuel, turbo, and BS3 sitting here. I wouldn't have to 'spend' any more, already have all the hardware
unit, this Formula already has a 12-bolt rearend and full suspension. It can handle some more power. I'd like ~750 rwhp on pump gas.
Old 05-27-2006, 08:41 AM
MIGHTYMOUSE's Avatar
a/c is an option from the factory
anywhere i go is in my car.
not touching tire pressure or race gas or changing tires or shock settings, straight from work, its been 10.77 at 136 on a 1.81
3800#, 18" tires up front 17" mt dr's on back
thats the number i will be working to knock down this year.
Old 05-27-2006, 09:37 AM
BUYAMERICAN's Avatar
Hmm.
I wonder.
I am running a 427 with two 60mm.. results to be yet know.
However, the theory is full boost at 4-5k to 7k.
Looking at the lastest Motor Trend.
Why reinvent the wheel. Case studies work best.
Hennessey Viper 522 cid. Full boost at 5,000-7,450
LPE 427 cid. Full boost 4,500-6,500
Full Cats.
Full Drivability.
The cars are both 1,038+rwhp capable and are obviously fast.
LPE trapped 151 on BFG's on the first run and hit 212 mph. in the mile.
The Viper trapped 153 on BFG's.
These are six speeds, so thats moving.
Note all cars had boost turned down to make less power.
I would venture to guess, based on past results I have seen they are at only 10-13 psi. of boost.
Viper 983/985, 7472
LPE 772/822, 6,500
MTI STS T GTO 789/788 at only 5,404
Theory one, with the larger stroker, boost is not needed at lower rpm and sufficient torque is already being produced vs. a 346-383.
Second theory, based on MT article, car is more drivable and civil on the street not being in full boost. Runs like stock.
Third theory. Car will be easier to drive on the road course looking at MT comments and HP chart.
Fourth theory. No additional wear on parts, until into boost and no additional heat.
Fifth theory. Curb weight at this power level is more important than increase in power. I am at 3,100 lbs.
Sixth theory. Differential. Take a one look at the twisted LPE differential tells all why the car is setup this way.
Up for serious debate for the, "Rebels with a Clue." Tuners & the real go fast people like ED at LPE, Might Mouse, Nine Ball, etc..
Old 05-27-2006, 10:51 AM
kp
kp's Avatar
Already thinking of tearing up that nice car lol.
Should have just cut the cage out of the silver one and put stock brakes on it
Old 05-27-2006, 12:13 PM
Administrator
unit213's Avatar
Ahhhhh...gotcha. I'd like 750rwhp on pump gas too please.
Old 05-27-2006, 12:40 PM
LS1Tech Sponsor
Slowhawk's Avatar
purevls is 100% street car. 408 t88...820 on pump
Old 05-27-2006, 01:12 PM
SScam68's Avatar
Thats a bit overkill just for 750hp.
Leaving room to grow?
Old 05-27-2006, 02:01 PM
LS1Tech Co-Founder
Nine Ball's Avatar
why? Then I couldn't have traded a 140K mile body for a 9K mile car with several nice parts and cash on top of the deal. The silver car was beyond the point of returning to the street.
Anyways, I decided to sell all the turbo and racing stuff and regroup while I think about some other plans
someone should jump on this turbo package deal
https://ls1tech.com/forums/lsx-parts-sale/515026-mega-parts-sale-turbo-nitrous-racing.html
Old 05-27-2006, 02:28 PM
kp
kp's Avatar
https://ls1tech.com/forums/showthread.php?t=515026
I know WHY you got rid of the silver car, but doing a BS3, single 88 and 408 plus trying to keep a/c, PS and keeping it mild mannered, super clean and not a headache seemed counter-productive considering you just got rid of the perfect car to put all that stuff in
Old 05-27-2006, 03:10 PM
qqwqeqwrqwqtq's Avatar
I think twins are easier packaged in a car you wish to keep all the accessories in.
I'm currently building a system with twin GT35R's that will keep all accessories in the stock location in my 2001 SS.
Old 05-27-2006, 08:30 PM
Josh@KY-Turbo's Avatar
I say go for it Tony. That car is bad *** now but will be wicked with a T88 408 and six speed. You wouldnt even need to run super hihg boost to make it nasty on the street. Just keep the setup clean. That car deserves it.
Quick Reply: How many larger turbo (80+mm) street cars?
