charge pipe sizes
Old 06-07-2006, 04:01 PM
12 Second Truck Club
TURBHOE's Avatar
Default charge pipe sizes
looking at getting started on my turbo setup. i'll be useing a duramx ic that i cut down a little for fitment. so to my question the inlet and out let on my ic are about 3" what size charge pipes are people useing. i was thinking 3" off the turbo to ic then from the ic start with 3" and work up to 3 1/2"
thoughts???
Old 06-08-2006, 09:17 AM
TURBHOE's Avatar
any body. i searched and didn't find anything unless i overlooked it. what size charge pipes are you all useing?
Old 06-08-2006, 09:27 AM
JAvenger007's Avatar
how much boost are you running? and what size turbo
Old 06-08-2006, 10:04 AM
TURBHOE's Avatar
7psi for now will go up later.
compressor: TO4R
.70 a/r
66.5mm inducer
flow: 75 lbs/min 960cfm
360* thrust bearing standard
turbine: T4
your choice of turbine housing
.58a/r, .70a/r, .84a/r, .96a/r, 1.00a/r, 1.15a/r available
available with 0 or P trim wheel
i think i got the .84a/r
Old 06-08-2006, 07:38 PM
TURBHOE's Avatar
with all these home made kit some has to know.
Old 06-08-2006, 11:45 PM
Jammer's Avatar
I think you right on with your initial thoughts
