Dyno today- breaking up above 4500 ?
Old 06-08-2006, 03:46 PM
MawneeC5's Avatar
Default Dyno today- breaking up above 4500 ?
Met up with Jeremy Formato(great guy!) to have my car tuned. And besides the fact that it kept blowing off intercooler pipes The car was breaking up above 4500. It would just start poping and lose power. It sounded like it was just not firing a couple cylinders. We never got a good dyno run above 5k really. He said the fuel looked good across the board.
The kicker is that when we ran it with one of the pipes blown off(no boost) it ran fine. It only seemed to have problem when running boost
We were thinking maybe I have a bad plug and/or they are getting blown out(gapped wrong).
Jeremy had another date halfway across the state so we had to call it a day. So now I"m going to take a couple of weeks to troubleshoot(and secure those pipes!) before trying the dyno again.
My car:
98 C5 6sp
P1SC with 4.0 pulley (showed about 7# @ 5XXX)
221\221 575\575
LT headers\ highflow cats\ Borla stingers
42lb green tops\ KB boost-apump
Plugs are ngk tr6 stock gap
What do you guys think ?
Old 06-08-2006, 03:50 PM
BlownBird68's Avatar
Whats your timing at?
8 sec potential, 12 sec slip
ChevyChad's Avatar
MAke sure your plugs are gapped at .035. Were you logging it while it was on the dyno?
Old 06-08-2006, 03:52 PM
MawneeC5's Avatar
I think he said he was running 16-22 through the curve, or vise versa.
Old 06-08-2006, 03:55 PM
How much boost? I had the same problem, i was at 18 locked out and didnt run to good so i put the timing at 36 and then pulled 10 out of that with my btm box. Its running alot better now .
Old 06-08-2006, 03:56 PM
MawneeC5's Avatar
I saw it peak around 7# at 5500ish RPM I think. I"m kicking myself for not grabbing some printouts from the dyno pulls
Old 06-08-2006, 03:58 PM
I would give it more timing, btw is this thing intercooled?
Old 06-08-2006, 04:19 PM
MawneeC5's Avatar
Oh yes, huge Front mount
Old 06-08-2006, 04:29 PM
LS1Tech Sponsor
Slowhawk's Avatar
Valves are floating
or the clutch is slipping
or the MA max setting is too low
Old 06-08-2006, 07:24 PM
2001WS6Vert's Avatar
Or coil, or crank sensor.
Old 06-08-2006, 11:14 PM
MawneeC5's Avatar
Well I pulled all the spark plugs. The back one behind the brake booster was broken, All the porcelen was gone from around it. I also checked the gaps, they were .037-.038.
So you guys think this was it ? If that plug was firing off the head at high revs It would explain the misfire.
Old 06-09-2006, 09:40 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Why is that plug broken?
Old 06-09-2006, 09:46 AM
MawneeC5's Avatar
It was the back one behind the brake booster, odds are I popped it while fighting to get it in
Old 06-09-2006, 01:34 PM
MawneeC5's Avatar
Well I just got it all back together again. I put in new TR6 plugs gapped @.032 and while I was at it I put in new plug wires. I also removed all of the piping and hairsprayed all of the couplings(mega hold!).
I took it out for a mildy spirited run and it seemed to run fine. Aside from my boost gauge fying off the dash..... repeatedly(I really need to get that mounted). I didnt push it all the way to the top..maybe about 5500rpm but I didnt feel any drop off or hear any misfiring. And best of all none of my pipes blew off
I think I"m going to give it a week or two and keep an eye(ear) on it. Then its back to the dyno.
