which boost controller with success
Old 06-08-2006, 06:43 PM
GTFORMULA's Avatar
Default which boost controller with success
I seached but didnt find anything.
I am looking at getting the EBOOST 2 and wondered if anyone has had good luck with it. What else is a good electronic controller. I want to be able to adjust boost at the touch of a button and have multiple settings. Thanks for any advise.
Old 06-08-2006, 06:48 PM
Spdmini's Avatar
HKS EVC EZ II is what I'm gonna run.
Old 06-08-2006, 11:41 PM
FormulaFire's Avatar
E boost 2 is supposably pretty good and there is one for sale in the For Sale section
Old 06-09-2006, 01:31 AM
98turbls1's Avatar
Do you have a link to that man?? i tried to search for it and didn't have any luck...Thanks
Old 06-09-2006, 02:32 AM
LastBlack02SS's Avatar
I hate to be the bearer of bad news but i actually paid for that one today.
Some news to help though, i've read up a lot on boost controllers. From what I've seen, there are a ton of different ones ranging in prices. There are only a few controllers that i have heard only positive things about. One was the Eboost2 which aparantly is easier to use, compact location in gauge pod, yada yda, and no problems. The other is the AMS1000 or something like that which is a buttload of $$$$$. I figured that since the Eboost would do everything i wanted and more, looked nice, and relatively simple once you spend a little time to figure it out, oh yea, and wasn't too much cash, i'd get it. Hope that helps.
Oh yea, its made by turbosmart. you can google it for their website to get info on it. same with the ams 1000 i mentioned.
Old 06-09-2006, 10:51 AM
GTFORMULA's Avatar
The eboost is probably what i will go with I just wondered what other people have been using that work really well for a decent price.
Old 06-09-2006, 11:03 AM
RW99's Avatar
If you do the eBoost2 I'd mount it in pretty sturdy locale... the button pressing takes some pressure, and if you want (or need) to goof with it much you'll appreciate having something to push against.
Old 06-09-2006, 12:06 PM
The Greddy Profec B is solid
Old 06-09-2006, 01:07 PM
Coal Mining Director
onfire's Avatar
EB2 has been very stable for me from 10psi to 16psi setpoints.
Apexi avcr was junk x 2
Old 06-09-2006, 05:15 PM
vhgjk123's Avatar
I hate mine. Huge learning curve and me or anyone that has messed with it can't get it completely right.
Old 06-09-2006, 06:02 PM
kwman's Avatar
Figured I'd throw in my .02.
In my experience (which covers ALOT of boost contollers) as far as EBC's go, I find the HKS EVC and Blitz SBC-IDII to be the best I've used. The Blitz is a bit tricky to install, but has the best display and controll of any I've used.
If I were you, unless you plan on running lower boost all the time (which without an EMS controlled fuel system using an "on demand pump" for boost would be useless) and turning it up when you line up next to someone, I say get a Hallman Manual boost controll (Hallman Pro-RX, Hallman ES, etc) and just set it and forget it (like ronco).
Reason being, i find that a ball and spring type is ALOT cheaper and easier to manage than an electronic system. No dealing with solenoids, no dealing with wiring.
If running high (pump gas) boost levels is a serious problem, THEN DRIVE SLOWER. Back off the throttle a bit, or run WG spring pressure. Then when you get to the track, or want to have some fun, pull'er over and make a few turns in the clockwise direction.
...just my .02
Old 06-09-2006, 06:03 PM
kwman's Avatar
^aside from that, an EMS with a closed loop system is the best IMO hands down. No problems and ECU managability, just make sure you know your system and how to change it when the time comes.
Old 06-10-2006, 10:35 AM
99f1's Avatar
apexi avrx...set boost per gear,and no boost spikes....$500
Old 06-10-2006, 10:42 AM
Senior Member
Country Boy's Avatar
the EB2 is nice, just get a manual job
Old 06-10-2006, 12:25 PM
LS1TECH Sponsor
DrTurbo's Avatar
The EB2 is awesome.
Old 07-05-2006, 08:47 AM
MTBDOC's Avatar
Can you detail the problems w/ the Apexi AVC-R? THANKS!
Old 07-05-2006, 08:56 AM
onfire's Avatar
Sure will. LPE installed three units (that I know of) that would hold boost when tuned, then over time the boost levels would change....some up some down...then stop working....I had one of the units and replaced it with a new AVCR and it did the same thing....could've popped a motor.....so that makes 4 units I know that went bad quickly.....the AVCR display gets very hot...I think the heat fries the internals over time...AVCR is the easiest to program by far....best looking by far....junk for reliability IMHO.
Old 07-05-2006, 08:57 AM
onfire's Avatar
BTW, I spent HOURS on the phone with the AVCR "techs"......they're not very technical.
Old 07-05-2006, 09:19 AM
MTBDOC's Avatar
Thanks for the VERY quick response...and I will stay away from that unit.
Quick Reply: which boost controller with success
