For $400 what would be better 6.0 heads or turbo cam?
OK, looking for some opinions. Let's say I have about 400$ to spend. Currently have a stock stock shortblock, stock 2000 cam and stock 241 heads. Going to be getting a TTi T76 street kit pretty soon.
Do you guys think I would gain more power by getting a custom turbo cam ground for me and using the stock 241 heads (with 10:1 compression), or using my stock 2000 cam and getting a set of stock 6.0 heads (for about 9.5:1 compression)?
Ya, used heads. I would give them a good inspection, but I really did not see a reason to have them professionally checked out. If they were used on a stock engine they should be OK I would think. I have had other used heads with no issues.
With lower comp with the 6.0L heads, you'll be able to run more boost and/or timing safely without the motor grenading. A stock cam seems to work pretty well, and I'm not sure with lower boost #'s, if a $400 cam is going to make a HUGE difference like a set of good heads.
Originally Posted by bowtieman81
While we are on the subject, do you guys with 6.0 heads use the 5.7 head gaskets or the 6.0 head gaskets?
I'd say go w/ the heads mostly b/c you're not going to want to spin a stock short block high enough to warrant going w/ a big cam at this point. But for $400 you can pickup a set of 317 heads AND an 02+ Z06 cam if you keep your eyes peeled. Eventually you'll probably want to go to a forged bottom end, and that's when I'd start looking at custom cams for your application.
Swapping the cam is much easier than the heads.
If you decide to do the heads it would be a crime not to spring for a cam and a set of new Comp 918 springs at the same time.
If I were you I'd drop the whole K-member motor combo so you can do the work and install the bulk of the turbo kit together.
I'm having a hell of a time installing this Incon kit (which is supposed to be one of the easy kits right? ), but it's moving along. If I'd have known what I know now I'd have dropped the motor twice before I tried to do it the hard way (motor in place.) ~Joshua
I agree swapping cams is easier than heads. But, the car will be partially dismanteld anyway to put the turbo kit on. Plus, I have done a head swap before so I know what to expect. I am mainly intersted in what will give me the best benefit or bang for the buck. Seems the heads will allow more boost/timing and have slightly better flow (more power for same amount of boost).
Hmmm, getting opinions both ways here.
Valvesprings are not needed, already have them from my cam-only setup. Going to check spring pressure, but they should be fine (only have 2400 miles on them).
Does anyone have any power numbers on what a turbo cam would get me with an otherwise stock engine?
New GM gaskets are only $35 for a pair, and already have ARP hardware.
OK, good point. Bear in mind I am coming from a n/a cam and nitrous setup.
Engine is stock 2000 shortblock
very mild ported 241 heads (basically just removed the intake bolt hump)
arp bolts
GM mls gaskets
ported oil pump
ported LS6 intake
ported TB
the rest of the mods will be coming off.
arp bolts
GM mls gaskets
ported oil pump
ported LS6 intake
ported TB
