what size cam?
Old 07-22-2006, 07:53 PM
extremez97's Avatar
Default what size cam?
im installing my own self built remote mount turbo using a t67 with an 84 backside in my 97z m6. im just refreshing the motor-gaskets, while i build another, i just wanted to do a cam install. ive already got 1.6 rockers,full-length headers, y-pipe and 3 inch exh. just want a good profile cam for the strip any ideas?
Old 07-23-2006, 05:22 PM
extremez97's Avatar
Anybody?
Old 07-23-2006, 07:28 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Intmd8 is the LT1 expert... he's been running a lot of small single pattern cams.
Old 07-24-2006, 01:03 PM
extremez97's Avatar
what do you mean by single pattern? liftand duration the same?
Old 07-25-2006, 01:47 AM
extremez97's Avatar
anybody got a little more specific info lift#s, duration #s???
Old 07-25-2006, 06:55 PM
extremez97's Avatar
not to many companies make what i think is a single pattern cam the only one i found for lt1 was lingenfelter which was 218/218 560/560 with 1.6rr
Old 07-25-2006, 09:01 PM
whynot's Avatar
you can custom order cams any size you want, but don't think that you are limited to just a single pattern cam, many use duel pattern cams, and do great with them.
but in the end, you have to decide what you really want to run, what rpm, are you after more low end mid, or top end?
and of course then you have those that say you can't have any overlap, but at 5000 to 7000 rpm's how much boost is going to bleed off and back feed with a few degrees of overlap, pretty much none.
so before you ask what cam you should run tell us what your goals are.
Old 07-25-2006, 09:42 PM
extremez97's Avatar
well right now im budget confined but im just looking for a quick street car with what ive got. stock longblock, 1.6rr's, full-lengths, 3-inch off rod y, 3-inch exhaust, remote mount t67 turbo-84 hotside, t56-shortthrow, 4.10, upperlower ca's, hardtop. eventually i would like to only race, but i have another engine that im sending out now for next year-lower comp, fully forged,etc
Old 07-25-2006, 10:16 PM
LS1Tech Co-Founder
I believe Jim is running a 218/218 to have excellent idle quality, but I think he made more power with a 224/224 cam.
Old 07-26-2006, 06:48 PM
extremez97's Avatar
does anybody know what the max lift you can run on lt1 before having to modify anything? is 560 to much
Old 07-27-2006, 12:02 AM
whynot's Avatar
changing anything will require doing valve springs, but I think .600 is about it, not positive though, but many are running gm847's with 1.6 rr's and that puts them at .595
lift on the exhaust.
Old 07-27-2006, 09:28 PM
extremez97's Avatar
what is gm 847s. what are the specs on that?
Old 07-27-2006, 11:28 PM
whynot's Avatar
234/242 .575/.595 w/1.6rr's 112 lsa pretty mean n/a cam.
Old 07-28-2006, 09:21 AM
LS1Tech Co-Founder
I think 234/242//112 is too much cam.
Old 07-28-2006, 07:35 PM
extremez97's Avatar
what do you suggest? im just looking for something i can purchase and not custom made....yet.
Old 07-28-2006, 08:46 PM
SS2win's Avatar
*edit*
Click me
Old 07-28-2006, 10:21 PM
whynot's Avatar
not for n/a, of cource I have seed a couple turbo cams even bigger than that.
Old 07-28-2006, 10:23 PM
Boostaholic's Avatar
I don't think its too much I think its just the wrong grind for a turbo car.
It kind of depends on what your going for though, most of the max effort cars run bigger cams than that.
whynot's Avatar
I would look around for something around 220 for your car, with as much lift as you can get away with.
