turbo question
Old 08-07-2006, 10:01 PM
cjg454ss's Avatar
Default turbo question
im fabbing up a custom rear turbo, 2002 ss, auto, w/3400 stall. i have slp longtubes, slp y pipe, and cat back, im thinking about this turbo for my setup in the rear. 10 lbs or boost max. what do you guys think?
Brand New Garret GT42-76 Turbo
Hot side A/R 1.15 T6 Divided Flange
Compressor A/R.60
Comes with 5" downpipe adapter w/v-band clamp and 3" compressor adapter
Turbo is good up to 1200 HP
Old 08-07-2006, 10:09 PM
Smearin's Avatar
Rear Turbo systems are sooo last year...
Old 08-07-2006, 10:11 PM
trtturbo's Avatar
way too much turbo if your just wanting to run 10psi
Old 08-08-2006, 08:32 AM
RealQuick's Avatar
That turbo is perfect if you want peak boost @ 6500rpm...
Try an MP T70... sometoing along those lines.
Old 08-08-2006, 06:35 PM
cjg454ss's Avatar
i just want room to grow, im gongi to stroke the motor later, what a/r should i loo for, im thinking more of a .81 a/r
Old 08-08-2006, 06:40 PM
frcefed98's Avatar
Sure you want to go with a GT42-76? Just asking because of the physical size of it and the location you are putting it in.
A T76GTS with a .96a/r will net you the same performance if not more in a smaller easier to package turbo.....
You guys really need to look at how big a GT42 is and how heavy @45lbs..and damn with the 1.15 a/r on a rear mount, good luck spooling it.
Old 08-08-2006, 06:43 PM
Zombie's Avatar
Way too much turbo for your application.
Think smaller, like a T70 turbo for your goals. Your stall will probably be to big as well and will have to be tightened up quite a bit. Run a small housing for faster spool, like a .68 a/r, makes it a lot of fun, espeically if you are only shooting for 10psi.
Get rid of the SLP long tubes and go back to stock manifolds and the turbo setup in the rear will work 2x better, I know because I ditched my POS slp longtubes.
Old 08-08-2006, 07:02 PM
cjg454ss's Avatar
is this turbo any good for 500 rwhp
http://cgi.ebay.com/ebaymotors/Turbo...QQcmdZViewItem
Old 08-08-2006, 07:05 PM
frcefed98's Avatar
Stay away from the SSautochrome turbo's they have been known to be of poor quality.
Old 08-08-2006, 07:07 PM
cjg454ss's Avatar
i know, but is that turbo an ok size for my application?
Old 08-08-2006, 07:11 PM
Boostaholic's Avatar
That turbo isn't really much of a T70, its closer to a T60, my MP T70 was about 10mm bigger across the whole wheel.
Old 08-08-2006, 07:21 PM
cjg454ss's Avatar
this one any good?
http://cgi.ebay.com/ebaymotors/Maste...QQcmdZViewItem
Old 08-08-2006, 07:37 PM
Yes mike is great to work with and who I purchased my turbos through, he even warrantied them when they had a hot shutdown / oiling problem and made everything right with me for cost of shipping.
They stock .68ar and .96ar exhaust housings with thoes too.
Old 08-08-2006, 07:40 PM
sr71's Avatar
there are 2 areas not to skimp on....your turbo and your wastegate.
many have had great luck with mp turbos and a few have had bad luck with them.
Old 08-08-2006, 07:44 PM
cjg454ss's Avatar
this one any good?
what turbo comes on the sts/?
Old 08-08-2006, 10:20 PM
As I posted above, even if you did have bad luck mike seems to take care of his customers, both of mine were rebuilt no questions asked for cost of shipping.
Quick Reply: turbo question
