Turbo placement??
Old 08-09-2006, 12:09 PM
topend's Avatar
Default Turbo placement??
I see alot of pics where ppl would put their turbos behind the radiator and just put an airfilter on the inlet of the turbo ,so it can suck in all the hot air from the radiator.I thought hot air=bad.Dont u guys worry about the hot air??
Old 08-09-2006, 12:35 PM
Boostaholic's Avatar
Well you can route a pipe and place your air filter elsewhere if you want, but the air is going to get pretty hot going through the turbo anyway, thats what intercoolers and or methonal injection systems are good for, cooling things down
Old 08-09-2006, 12:41 PM
y2khawk's Avatar
If you can duct cool air, you're alot better off. But, if you can't fit inlet plumbing you're stuck with what you got.
Old 08-09-2006, 12:44 PM
TchargedLS1TA's Avatar
Its what intercoolers are for..
Old 08-09-2006, 12:45 PM
frcefed98's Avatar
Yep things get cramped real quick, so you have to work with the space you got. I had to put the air filter on the turbo because of a measurement error when fabbing up my kit measure twice, cut once....
J
Old 08-09-2006, 12:49 PM
y2khawk's Avatar
No, that's not what intercoolers are for.
You can only get a delta temp drop across the cooler. Any compressor will add heat as it compresses the air, depending on the efficiency, pressure ratio, etc, but that heat is added to the temperature of the air ENTERING the turbo. The intercooler is there to help remove the heat you added by compressing the air in the first place.
If you start with 150°F underhood air and then compress that, and then try to cool it, you'll be lucky to get back to 170° if you're leaning on it any.
Get 70° air into the turbo and you'll be much happier.
Old 08-09-2006, 01:04 PM
smokinHawk's Avatar
ya, i agree with Matt.
smart people have their turbo getting air from their foglights
https://ls1tech.com/forums/attachmen...chmentid=46403
Old 08-09-2006, 03:06 PM
topend's Avatar
what u recommend for ducting??? something simple because i dont have access to welder.
Old 08-09-2006, 03:22 PM
smokinHawk's Avatar
you can use silicon and right angle bends coupled together if you dont have a welder.
Old 08-09-2006, 04:06 PM
y2khawk's Avatar
dry vent hose = cheap, quick, easy
Old 08-09-2006, 04:20 PM
black_z's Avatar
dry vent hose = cheap, quick, easy, ghetto
fixed it for ya matt.
Old 08-09-2006, 05:36 PM
98hardtopZ's Avatar
who would see it? you can paint it black
Quick Reply: Turbo placement??
