catch can needed please help
hey guys im still buying alot of parts for my build,but im now in the catch can part of the build im going by this route a member posted for the pcv system for boost.basically were can i get a can with 2 in ports and 1 out port?because they posted it will be bad to run the lines into a 2into1 fitting and then to the can.
so wats posted above is wrong?i already have a GN check vavle which i bought from kirban motorsports.my passenger side cover has 2 ports and i stil have to buy the ls6 vavlley cover.so what should i do for a trouble free setup?
no ur getting confuse a line from one port on the cover and a line from the ls6 valley cover go to a catch can and then to the airfilter on the turbo,then the rear port on the cover gos to a port behind the throttle body which has a check vavle in the middle.i know the drawing is bad
Senior Member
Originally Posted by Boostaholic
The line that goes from your intake to valvecover to catch can is wrong
That drawing isnt wrong. Its mine. There was 2 of them that I made. The one posted has a line from the valvecover tee'ing to the LS6 cover to the can and then to the inlet side of the turbo. Then one from the other valvecover boss to the intake port with a check valve to pull a vacuum at idle and the check valve closes as positive pressure is introduced.
Senior Member
here is a example
Good call
yall are so newbs at drawings...
i changed mine around some
passenger rear plug == small filter
driver rear plug == small filter
driver front plug -> catch can -> turbo inlet
ls6 valley -> check valve -> intake manifold
