Differances between Methonal and Denatured Alcohol
Old 08-19-2006, 04:07 PM
00turboT/A's Avatar
Default Differances between Methonal and Denatured Alcohol
Like the title says I have seen people running Alcohol. I have seen people running methonol. Is there an advantage over either one???? Is there any differance based on set up???
Old 08-19-2006, 08:54 PM
Mr.Big's Avatar
Very interested in this one as well... Bump...
Old 08-19-2006, 10:02 PM
Blown SS's Avatar
Meth is alcohol
Old 08-20-2006, 03:09 AM
00turboT/A's Avatar
Originally Posted by Blown SS
Meth is alcohol
I know its a type of alcohol. But there is methonal and there is denatured alcohol two seperate things and I have seen people run both. So is there a differance or no
Old 08-20-2006, 01:06 PM
bowtieman81's Avatar
Perhaps you should worry more about your reputation and character instead of what methanol to use.
My apologies to the mods.
Old 08-20-2006, 02:24 PM
Draco's Avatar
Methanol is methyl alcohol. Denatured alcohol is ethanol (ethyl alcohol) with a denaturing chemical added to make it poisonous (often methanol is used to denature).
Methanol has lower energy content per unit mass of fuel then ethanol.
Methanol has a lower stoich AFR then ethanol, which means you must inject greater volumes to achieve stoichiometry.
At stoichiometric AFR ratios, methanol combusts with more energy (BTU's per lb of AIR) then ethanol, which means it has the capability to make more power.
Methanol has a higher latent heat of vaporization, which means it removes more heat from the surrounding air when it evaporates. This allows it to have a greater IAT cooling effect then ethanol.
Methanol has a higher octane rating then ethanol.
In short, Methanol will cool better and provide more power then ethanol, however you must inject it more of it per lb of air due to the low stoich AFR. Methanol is also usually cheaper then denatured alcohol.
Old 08-20-2006, 03:14 PM
00turboT/A's Avatar
My reputation is fine and so is my character. No matter what you do in the world you can't make everyone happy. We had a bad deal on both ends so walk away and move on to the next. Quit posting stupid petty bullshit in my post.
00turboT/A's Avatar
Thanks man thats exactly what I needed to know.
Old 08-20-2006, 03:37 PM
Mr.Big's Avatar
Thanks Draco...Much appreciated...
Jeremy
Old 08-20-2006, 06:52 PM
cablebandit's Avatar
wow...easy answer but none of us knew!! There you go Matt...you better switch to ethanol...I got a 5 gallon can of it friday!!!!!
Old 08-20-2006, 08:41 PM
00turboT/A's Avatar
Good you'll have to bring it to the track and I can get some from you You won't need it to long since you only made 820RWHP
Old 08-20-2006, 08:44 PM
I will bring it Friday of course. Where we going? I wanna hit either paradise...steele....or brainard.
Old 08-20-2006, 09:04 PM
ATTI2D's Avatar
I have noticed though..that Meth is more prone to attract moisture.
Quick Reply: Differances between Methonal and Denatured Alcohol
