370 c.i Iron block with vortech ????
have any of you guys encountered problems with vortech T.Trim .
sume guys told me the vortech T.Trim its small for 370c.i Iron block ????
thanks
navy
thanks
navy
the aftercooler should be ok, what rmcr is doing is cutting off the nipple on the aftercooler and welding a bigger one, that will help the restriction. They said that aftercooler is good for the YSI up to 15 lbs. I believe its where it necks down that causes restriction and makes more heat not that the aftercooler cant do its job.
