sts rear mount #'s on a stock car
are any of u guys running a sts rear mount on your ls1 thats pretty stock?..what are ur dyno #'s? and what are ur track #'s?...........just askin cuz a kid around the way just got his put on his stock ls1 and i know his car isnt no where near as fast as he thinks it is...so any numbers would be appreciated.
Originally Posted by longrange4u
Define stock:
My numbers below reflect a stock block... with upgraded fuel injectors and 6.0L factory truck heads.
Nope... my fuel was just 42's with a Walbro 255 on stock fuel lines and wiring. I would not suggest that for someone else. I would reccomend something like the racetronics harness a walbro 255 and 60# injectors.
a stock a4 will make 428 rwhp at 5ps1 no intercooler, you should see around 500 rwhp at 8 psi and you will need meth or intercooler to safely run that. my time is in sig, 5 psi no intercooler.
yea this guy has just a lid on his car....he had a catback but had 2 put on the stock exhaust for the t-bo...so yea he is an extremley stock car..but he seems 2 be tellin everyone low 11's with just his 5psi on his stock car..which i said was never gonna happen but i guess when he actually runs it he will see 4 himself
Originally Posted by 67Firebird455
I'm running the racetronix pump and harness on mine along with FMS green-top 42lb injectors (I believe at our fuel pressure running 48lb). I really should step it up to a set of mototrons to be safe. What was your inj duty with the 42's?
On my 607RWHP run? If I remember it was 97%.... and I was spraying oil out the back with blowby.
Yea I was taken back by that too... I kinda think the dyno wasnt getting a good read on the duty cycle. I just dont know how it would be possible for me to push the setup that hard without maxing out the injectors.
My AF was right at 11.4 through the whole pull though...
I haven't auto-tapped but...my fuel psi goes from 61 down to 58/59 psi but my a/f ratio goes below 11.0 (lowest reading on AEM wideband). I got the 42lbs based on some online calculators and my target hp.
