What compression for sts
Old 08-30-2006, 01:21 PM
Tiger2o69's Avatar
Default What compression for sts
Just bought an sts kit with a gt67, methonal injection, no intercooler but I plan to add one...
Im in the process of trying to figure out what compression to run. I know that lower is better because I can get higher hp with 93 octane.
I have been trying to figure out the compressor map for a 347 block.
My big problem is I dont want to go too low of compression because I dont want to change turbo's.. It seems if I go lower compression it will have to work the turbo harder to get my hp which will be bad for my smaller turbo
I have been thinking about 9.5:1 or maybe 9.1:1 compression... does this sound about right?
My goal is 600-650 rwhp.. Maybe not even that much..
Old 08-30-2006, 01:24 PM
longrange4u's Avatar
Unless I am wrong... Blocks dont have compressor maps... turbos do.
IMHO I would go somewhere close to your 9.1 with your goals. Get that FMIC too...
Old 08-30-2006, 01:37 PM
67Firebird455's Avatar
I'll agree with you bud. 9:1 should work out okay for you. Don't wanna get too low, like you said, losing power under the curve. 600rwhp I believe is obtainable with that turbo, look at longrange, he's the man with the 67 trim!
Old 08-30-2006, 01:42 PM
LS1TECH Sponsor
DrTurbo's Avatar
I think he's refering to consumption charts for the 347. You can find one close to the 347 at the link below in the sig and check the Turbo help section.
Old 08-30-2006, 02:44 PM
Tiger2o69's Avatar
lol... I meant the gt67 compressor map in reference to a 347 block... What do you guys shift at?
Old 08-30-2006, 04:18 PM
ninetres's Avatar
Redline
Old 08-30-2006, 04:48 PM
Tiger2o69's Avatar
my redline is 6600.. I dont think the turbo will make it that far.
Old 08-30-2006, 04:50 PM
Sixspeed02TA's Avatar
Originally Posted by ninetres
Redline
Classic
Old 08-30-2006, 05:01 PM
Where you shift should be determined on your power curve... I used to shift at 5200 with my 67
Old 08-30-2006, 05:11 PM
Tiger2o69's Avatar
Holy ****! 5200 I can see Im going to have problems alreay. My vig 3500 is too big.
Do front mounts run up to higher rpms? Maybe thats why I see lower ets with higher hp with the sts kit
With nitrous I could run 10's with 500hp.. With the sts kit it looks like It takes 600+ for low 11's
Im thinking about adding a small shot to my kit.
Old 08-30-2006, 05:20 PM
Yea I think you need ~600 RWHP with a STS for 10's. I was at 607 and was trapping 10 sec times on a shitty track. I could have had high 10's with my old setup at a good track.
