AllPro FI head guys... what plugs are you running?
Old 08-31-2006, 12:20 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Default AllPro FI head guys... what plugs are you running?
Part #?
Mightymousy?
Old 08-31-2006, 12:24 PM
danimal95's Avatar
TR8's are already in your car John
Old 08-31-2006, 01:43 PM
V6 Bird's Avatar
Where do you guys buy these Tr8's? Everytime I look them up at the local parts store they cant find it them...
Thats because they dont make them! NGK R5671A-8's No where on the box does it say TR8
Old 08-31-2006, 03:12 PM
MIGHTYMOUSE's Avatar
NGK 7173 i have posted a photo of it before
it is the cross reference for an autolite ar 3911 exept with a full tip for longer life
you will definitely mess up the plug threads if you jam an acorn seat plug in an all pro head.
Old 08-31-2006, 03:52 PM
danimal95's Avatar
you would be correct,lucky for me the plugs are just started be hand and no tightened yet thanks
Old 08-31-2006, 03:55 PM
danimal95's Avatar
is that the correct part # for a plug with a similar heat range to a TR8??
Old 08-31-2006, 03:58 PM
i know it is colder than a tr-6, but i didnt get that far into it.
Old 08-31-2006, 10:27 PM
V6 Bird's Avatar
http://www.ngk.com/more_info.asp?AAIA=&pid=3252
http://www.ngk.com/results_cross.asp?pid=TR6&x=0&y=0
the top part number says nothing about TR anything in it...is there something we are missing here
Old 05-09-2007, 07:47 PM
LS1Tech Co-Founder
Bringing this one back up.... Dave you mostly running 7173's right now? Are you running gasketed plugs for your AllPro heads?
Old 05-10-2007, 07:25 AM
7173 is whats still in the car, they are gasketed, they are a cross reference to an AR-3911 but with a full tip (last much longer, normal life plug), all pro's do not have a taper seat
Old 05-10-2007, 09:08 AM
LS1Tech Co-Founder
Thanks Dave. What did you gap yours at? I've got a full set of 3911's around, but only a half set of 7173's. I hope to make a few passes pretty soon.
Old 05-10-2007, 10:04 AM
the 3911's will lose the tip fast and gap open, this was a problem for me in a street car applicatioin, but if they are new they will perform as good as the 7173
i used them as gapped from the factory at .030 or 35 i think
Old 05-10-2007, 11:58 AM
LS1Tech Co-Founder
Thanks been a while since I tinkered with the Formy. I'm spacing out (maybe lack of sleep due to new baby), but what was the concensus around the AllPro heads, we need a gasketed plug since the plugs are more recessed?
Old 05-10-2007, 04:10 PM
because the heads are not machined to accept a tapered seat (normal style) plug
if you try a standard style plug you fill f up the first few threads into the head
Old 09-18-2007, 11:41 AM
LS1Tech Co-Founder
Dave you street drive on these? How long you get before you need to change them? Just curious?
Old 09-18-2007, 01:36 PM
black98ws6ta's Avatar
I am also interested in the correct plug for a standard head in a 7-8 heat range. I had zero problems with tr6's at 900 rwhp but im guessing colder is safer.
Old 09-18-2007, 02:05 PM
Websy21's Avatar
Curious as well I am going with the TR-7's, whatever part number they are??? Don't have them infront of me, I think they're the one's you guys are talking about, I hope
Old 09-18-2007, 03:18 PM
LS1Tech Co-Founder
This thread was for the AllPro heads, since they are machined a little different and so require a gasketed spark plug.
Old 09-18-2007, 03:29 PM
yes this is the plug that stays in the car full time. i have not worn out a set yet, but i have replaced them when doing head gaskets etc. just for good measure.
they will last as long as any other normal car spark plug would. they are not a racing fancy tip short life type of plug.
Old 09-18-2007, 03:46 PM
LS1Tech Co-Founder
These ones right Dave?
http://store.summitracing.com/partde...5&autoview=sku
Quick Reply: AllPro FI head guys... what plugs are you running?
