Heat wrapping crossover gained 3 psi
Old 09-02-2006, 09:31 PM
bowtieman81's Avatar
Default Heat wrapping crossover gained 3 psi
Just thought it was interesting that after wrapping my crossover with header wrap I gained abou 2.5-3 psi of boost with no other changes. I did not touch the wastegate after wrapping just to see what it did.
Boost went from about 8 to 11 psi.
Old 09-02-2006, 09:49 PM
iamsickofitall's Avatar
sweet deal...didn't think that much heat would be lost over such a short distance to cause that big of a change
Old 09-02-2006, 10:11 PM
I thought it might pick up 1 psi, but not 3. The other good thing is that not as much heat is transmitted to the stuff near the crossover now.
Old 09-02-2006, 10:54 PM
WestSide's Avatar
Definitely going to have to wrap my kit now, whenever the freaking turbo blanket GP happens!
Old 09-03-2006, 05:59 AM
Senior Member
Country Boy's Avatar
sure there wasnt a leak somwhere? Thats a lot of psi to pick up with just a short run. Good deal though!
Old 09-03-2006, 07:54 AM
BrandonDrecksage's Avatar
+1 thats kinda weird.
Old 09-03-2006, 09:29 AM
engineermike's Avatar
What's the design of the kit? Is it front mount? What, exactly, does the crossover connect?
Mike
Old 09-03-2006, 09:37 AM
I am 99% sure I had no leaks, however I may have had a slight one that I could not pick up on. I think it is mainly due to my crossover being 18 gauge wall mild steel. Loses at lot of heat.
The crossover connect my passenger side stock manifold to the drives side log header. Length of the crossover is about 3.5 feet give or take a couple inches.
Old 09-03-2006, 10:30 AM
Restricted User
NOSjohn's Avatar
Good work !
Old 09-03-2006, 01:19 PM
52172's Avatar
wow!! Is wrapping much more effective than coating inside and out? Is it worth wraping along with coating?
Old 09-04-2006, 07:20 AM
BlackCamaroSS02's Avatar
Damn might have to wrap my entire hot side after reading this lol should help a little.
Old 09-04-2006, 10:36 AM
My opinion is wrapping would be more effective than coating, but doing both probably would not hurt. I was surprised it picked up that much too, but after running the car I could touch the wrapping and not get burned. Maybe I can get some wrapped/unwrapped temps for you guys. I have a laser thermometer; if I remember I will use it and see.
Old 09-04-2006, 11:35 AM
yeah..maybe try unwrapping it and see if you loose the 3psi again.
Old 09-04-2006, 01:40 PM
67Firebird455's Avatar
That's crazy. I'm definitely doing that on my rear mount. If your results were that well on a front mount, mine should be just as good, if not better on the *** mount. Keep us posted.
Quick Reply: Heat wrapping crossover gained 3 psi
