Exhaust Restriction
Old 09-24-2006, 12:25 PM
bigturboz28's Avatar
Default Exhaust Restriction
1. Will a T67 .68A/R restrict the exhaust to much if the goal is 525rwhp (stock M6)?
2. On a stock block M6, what rpm will you see 10psi in fourth?
Old 09-24-2006, 02:03 PM
Anyone?
Old 09-24-2006, 02:19 PM
ninetres's Avatar
3642.11793 rpms.
jk. Really though, there are too many variables to have ANY clue with the info you provided.
EDIT---Just saw you have a somewhat detailed sig. I still think it will be hard to tell what rpm you will see certain boost at in each gear.
Old 09-24-2006, 02:44 PM
Fair enough about the RPM thing (I like the answer though, i was hoping someone could have been a little more accurate, I mean really only 9 significant digits ). Anyway, what about the exhaust restriction thing, any comments, is there anything else you need to know about the car? Will the .68 A/R on a T67 choke the hell out of the engine?
EDIT: Exhaust uses Edelbrock shorty headers, then 2" ID pipe goes down and under the K-Member and join right in front of the K-Member (between engine and rad).
Old 09-24-2006, 03:18 PM
Anyone?
Will the .68 A/R on a T67 choke a stock engine before 525rwhp?
Old 09-25-2006, 12:02 AM
I can not believe that nobody knows.
Old 09-25-2006, 12:07 AM
LS1TECH Sponsor
tt427ls1's Avatar
I Would say your going to run out of air on the top end with a .68 turbine housing. I would get a .96. I used the .96 on my kits and it pulls 520 rwt from 4000 to 5500. Its really nice.
Quick Reply: Exhaust Restriction
