whos car is this?
Old 09-26-2006, 02:51 AM
my01ws6's Avatar
Default whos car is this?
http://videos.streetfire.net/search/...8849a81498.htm
Just wondering whos car this is? or if anyone knows what all he has done to it?
Old 09-26-2006, 12:45 PM
rudyzturbota's Avatar
well it was a ace hole crook that i bought it from in texas, since then ive put over 5k in it, but yah thats my car, i had it re tuned an dynoed. its runnin at 470rwhp an 510rwtq. i about got every thing straightin out an all the buggs work out. its basically a sts setup on a 2000ls1 motor, 42-50 injectors,flowtecheaders, an 373gears.
Old 09-26-2006, 01:12 PM
my01ws6's Avatar
how much boost are you running?
Old 09-26-2006, 01:30 PM
well as soonn as i bought the car the turbo that was on it was a 67mm with no oil going to it, thats why it lock up, i put a 76mm on it now an im running 7psi, untill i get my bottom end forge.
Old 09-26-2006, 02:24 PM
my01ws6's Avatar
so what did you have in the video?
Old 09-26-2006, 07:55 PM
not sure exact what he had in the video, but i know he set it up poorly, hell the first week i had the car the turbo lock up on it, then i went to get it tune, an it woundnt tune right. all i know is he told me abunch of lies, so who nows. even the guys from sts said that the guy i bought the car from was a dooshbag. but at least i know what ive got done to it.
Old 09-26-2006, 09:50 PM
my01ws6's Avatar
how do you like your 3.73s with your turbo? is it less of a load?
Old 09-26-2006, 10:15 PM
JAvenger007's Avatar
I'd lose the LT's and go back to stock gears.
Nice vid. Good choice in putting the camera guy in the vette. even out that weight advantage
Old 09-26-2006, 11:39 PM
SilverSS's Avatar
Off topic but anybody know the song on that video?
Old 09-27-2006, 12:20 AM
know im pretty sure that would be the car i have, i could be wrong, but how many black sts transam with stock chrome wheels, name matt an live in texas where an the same name of the guy i bought the ta off of. also do you see the smoke(oil) coming off the back of it, that because he didnt install the oil line correctly. from when i first bought the car to now, id say its fast an more reliable after i had to go back an fix everything he fock up installing it. thanks for the compliment even tho thats not me racing, but as for the car its the same,but runs alot better.
Old 09-27-2006, 12:21 AM
[QUOTE=JAvenger007]I'd lose the LT's and go back to stock gears.
why do you say that
Old 09-27-2006, 07:46 AM
V6 Bird's Avatar
Pot calling kettle black..
STS calling previous owners douchebags, but they are selling rear mounted setups..hmm. Carry on.
Old 09-27-2006, 11:10 AM
why do you say that
Theres a lot of science behind it and youll want to poke around in the STS threads concerning it but in short:
Most owners (TRT and EPP ect as well) are starting to see better results with either stock manifolds or shorties that are wrapped (and if possible) ported. LTs dissapate heat and turbo also needs the pressure as well as velocity which a long header will help flow well on an N/A supercharger car but will hinder spool. Not to mention stock manifolds are strong and can take the heat. IIRC, the best setup is a ported set with wrap or insulation (or both maybe). Ive heard painting the wrap also helps seal it from water which is what leads to them cracking and rust
Old 09-27-2006, 10:04 PM
itsmike's Avatar
any idea what paint to use? my sts kit should be here soon and i want to do the wrap but since it rains here in so cal i want to make sure it doesnt mess anything up.
Old 09-27-2006, 11:13 PM
wow, never knew, sounds like a great idea, thanks for the info.
Old 09-27-2006, 11:21 PM
I think its that exhaust paint stuff straight from autozone. The 1200 degree stuff. Search for Zombie's thread hes got a lot of good info and the rear mount guys hes with seem to have done some experiments as well.
Old 09-28-2006, 01:01 AM
venom ws7's Avatar
the song is colors by crossfade
Old 09-28-2006, 01:40 AM
i found some manifolds off of a hummer that has a 6.0ls6 motor in it, well those manifolds work on ls1 for transam?
