How restrictive is it to run stock manifolds?
Old 10-03-2006, 07:22 AM
snketr's Avatar
Default How restrictive is it to run stock manifolds?
I'm hopefully starting on my front mount next month. I was going to make my own headers but the thought of saving a **** ton of time is intriging. Are the stock f-body manifolds to restrictive? Or should I get a pair of shorty headers? I'm not doing truck mani b/c I will have A/C.
Old 10-03-2006, 11:28 AM
snketr's Avatar
My goal is 750 to the wheels. So, I'm assuming they aren't advised. Thanks.
TchargedLS1TA's Avatar
We have seen good success with stock ported and coated manifolds.. They have less surface area than headers, so heat is dissapated less, which is what you want in a turbo setup. Would they do well on a 800+ hp car, I dont think so, but for a street car they will do just fine
Old 10-03-2006, 05:07 PM
Jammer's Avatar
TWNTRBO CE runs mid 8s with cast manifold from a truck...as far as i remember anyway
I think hes 2nd on the 2006 boosted list.
Old 10-03-2006, 05:12 PM
F8LWS6's Avatar
Old 10-03-2006, 06:22 PM
Possible Scammer - Buyer Beware - Issues Unresolved
00ls1's Avatar
he said he doesn't want to run truck manifolds he wants to run f-body manifolds
Old 10-03-2006, 11:05 PM
pekkaz's Avatar
Is there really huge difference in flow compared to truck manifolds ?
Old 10-03-2006, 11:51 PM
Jammer's Avatar
Okay, so he only has 8.70s potential instead of 8.50
Seriously, i dont think there muck or any true flow difference.
Old 10-04-2006, 02:38 PM
Truck manifolds flow probably twice that of LS1 manifolds..
Old 10-04-2006, 03:17 PM
ninetres's Avatar
I could be wrong, but I don't believe you can flip the stock LS1 manifolds facing foward in an Fbody....clearance wise.
Old 10-04-2006, 03:19 PM
Zombie's Avatar
That's a pretty bold statement to make without any hard numbers.
Old 10-04-2006, 03:23 PM
snketr's Avatar
I'm not flipping them. I plan on using them how they are designed to be run and then making the pipes face forward. after the flange.
Old 10-04-2006, 03:42 PM
Ping King's Avatar
take it from someone whos built 5 trillion turbo setups..and not been satisfied with 4,999,999,999,999 of them. Use truck manifolds.
Old 10-04-2006, 03:47 PM
snketr's Avatar
Are you saying flip them forward like most do or just use them in general? I don't want to flip them for the loss of A/C. This will be a street car and street cars to me have A/C
Old 10-04-2006, 03:51 PM
Ping King's Avatar
if thats what you want. In reality what youre planning on doing may not work out too well with the routing of Downpipes and such, while still having ground clearance, and still making power.
Old 10-04-2006, 03:52 PM
snketr's Avatar
So then I'm stuck with making my own headers I guess.
Old 10-04-2006, 03:58 PM
Ping King's Avatar
not necessarily..i was gonna run twins off of stock manifolds with a small flange adapter, basically imitating the incons, but i didnt want to deal with scavenge pumps and such..so i just ran truck shorties, a huge single, and a 4 inch Dp over a stock k member. No AC though.
Old 10-05-2006, 06:42 PM
Mike 01WS6's Avatar
I believe you could run a flipped truck manifold on the driver's side facing forward and run another pipe from the passenger manifold around the back of the pan merging into the driver's side hot pipe in a "Y"......TTi street kit style. You can keep A/C that way.
Old 10-06-2006, 04:57 PM
MiaSSmaro98's Avatar
Similiar To A Pts Kit.was Going That Route By Then I Went Another.i Ported My 2002 Fbody Manifold To The Same Size As A Truck But U Can Always Buy Shortys Like Mac Edelbrock Exc And Only Use One
