i need help with this setup? (wastegate)
ok i bought a custom turbo setup and am unsure how the wastegate works into it! ok its a log style with the passenger side that crosses over and connects to the back of the driver side log. and the wastegate mounts to the cross over pipe! how does it regular the psi there? im so cofussed!
Sounds like a TTi kit. The WG regulates boost by dumping exhaust gas before it gets to the turbine. It will work fine on the crossover unless you are wanting to run rediculously low boost or the WG is too small in flow.
