What thread is oil feed on a ITS turbo ?
I assume thats 1/8 NPT then ???? ( 1/8 BSP would be more common in the UK, although most stuff is metric )
The fitting they supplied ages ago, is -3 on one side, and unknown on the turbo side.
I need to source a -4 fitting as you say, so I can hook it up to the engine, as thats the size of the adaptor in the block.
Sorting a -3 fitting for the block might be awkward too.
Yes - 1/8NPT on one side and -4AN on the other side. If you buy your fitting from a decent turbo shop, this is what you'll get and this is the standard for a t3 and t4 turbo.
