Installed procharger and no boost
What rpm are you getting up to? Is your belt tight? Are you sure your not leaking boost anywhere? Did you forget to take the plastic bag off the air filter ( I did this one what an idiot)?
pass side by the computer? what the little 3/16 or whatever size line it is coming off the back of the intake for the ac controls? if so, did you splice infront of the inline check valve or behind? behind wont yeild boost due to the checkvalve.
Originally Posted by SKI
After the valve.
After the valve.
Is there really any need for a boost gauge? just curious?
Originally Posted by 1BADAIR
he's talking about the HVAC check valve. if the valve is bad or missing your heater blend doors will move(floor to defrost) as vacuum changes
