408 folks please chime in!
Old 10-15-2006, 10:26 PM
Mr_president's Avatar
Default 408 folks please chime in!
so if you dont mind, what cam are you guys running in your 408 strokers and what power and tourqe did you put down, and when is your full boost?? thanks guys!
im getting ready to start my 408 build and need my familys (you guys)help!
Old 10-15-2006, 11:36 PM
Jammer's Avatar
I run a 230/226 reverse spilt .58x lift on each side on a 114
I have had several set ups, but general ballparks are about 600 hp 625 tq at 8 lbs boost (that was twin rear mount running out of injector). Full boost like 4200
On the twin fronts It was a little taller number wise at the same boost. Full boost like 3800.... but often crept up due to system design.
I have a 9" w/ 3:50's and a 4l60... 6 cyl Envoy converter.
Old 10-16-2006, 12:01 AM
trtturbo's Avatar
The last 2 408s we did had 232/228 .588 .595 114.
We have also run a 220/224 .58x's 114
Old 10-16-2006, 12:39 AM
trtturbo i like this one alot!! 232/228 .588 .595 114 seems like a small cam for a 408 for good midrange power and faster full boost~!
Old 10-16-2006, 10:35 AM
trtturbo's Avatar
We will see some results soon with it.
One is an F-body, 408, powerglide w/TB, Neil Chance converter, t-70 STS.
The other with that cam will be a while. '93 Reg cab Chevy with Twin 60-1's, 4L80, etc..
We did the smaller cam in a Silverado SS, 408, STS. We just have to finish the fmic on it.
Old 10-16-2006, 11:59 AM
TrakDay's Avatar
I am also interested. Mostly just in the cam selection as I need to have another cam done for me. Supercharger -> Turbos = new cam again! ugh
Old 10-16-2006, 03:17 PM
Navy David SS's Avatar
TondSS. Every one has their own goals. Each cam is going to be a little different. Mine is done from Cam Motion - via W2W. 24X/24X 64X/61X 115. 408 iron. Twins. IMO just call Cam Motion or W2W ask them to advise you. My cam is not all that big for street use.
David
Old 10-16-2006, 03:33 PM
obZidian's Avatar
hmm...
Well, my motor is getting ripped out now and currently im running a 246/248 613ish/615ish 114. Most likely we would end up going with something smaller, less lump in it, but theoretically it could work...
Can anyone jump in and add why run a split cam instead of a even 230/230 type of cam?
Old 10-16-2006, 05:01 PM
Originally Posted by obZidian
hmm...
answer..........split cam will help make your boost come in faster and with a smaller cam youll have lower power ...... we did a test I put a small cam in and my friend put a big cam in and he doesnt hit boost till 4000rpms........
Old 10-16-2006, 05:20 PM
ninetres's Avatar
You are so full of **** sometimes its funny.
You really should stay out of techincal disscussions (not this thread, but the reverse split vs even split cam debate) unless you know what you are talking about. There was no "test" like you are claiming, unless I never heard about it.....and I think you are trying to refer to my car, which sees spool by about 3500, just like yours did when you had a 6 speed.
Old 10-16-2006, 06:33 PM
other then this thread can you show me anyother technical discutions ive had on ls1tech??
I found my dyno sheet and looking at mine and seeing yours, i make 500hp at 3000rpms.bro i wasnt talking bad about it but we can consider it a test of some what i put a reverse split baby cam in and you put a nice cam in. i was refering to your car but if someone can chime in, And elaborate on this subject of smaller cams ( help spool the turbo faster then a bigger cam) that would be great . pleease also talk about the reverse split helping spool faster.......(if this is true
the fact is a small cam will help spool the charger faster. sean you know i think your car is fast i might add his cam is a nitrious cam with out a reverse split and has a lift upwards of .595 witch is a bit big for a 346 in my opion.....
Old 10-16-2006, 09:19 PM
ninetres's Avatar
I call some SERIOUS BS about you making 500 whp at 3000 rpms
Old 10-16-2006, 09:44 PM
engineermike's Avatar
My cam must be all wrong then. . . 224/236-114 on 388 cid with a T76GTS.
Mike
Old 10-16-2006, 10:42 PM
you have bigger cubes so you will make a differnence on spool time i will be getting something of that size!......
Old 10-16-2006, 10:46 PM
still no answer or post
Old 10-16-2006, 10:53 PM
ninetres's Avatar
You misunderstood me. Since you started this thread......it would be stupid for me to say stay out of a technical thread. But you tried getting your toes wet in the whole "turbo cam effect" theory when you actually have NO IDEA how cam profiles effect spool and and power.
There is no "proof" that a reverse split is ideal for turbos. There are many threads already out there that cover this debate and many knowledgable members have valid points and have tried different cams in the same car. You have not.
Old 10-16-2006, 11:15 PM
Old 10-16-2006, 11:29 PM
BAD FNZ's Avatar
wierd.... 224/230 @ 114 here... I think it feels just fine..
Old 10-16-2006, 11:46 PM
what are the lifts on your cam what is your lsa?? im not saying it wont spool fast with a bigger cam or your car wont feel good howbout this post your dyno sheet to compare!
Old 10-16-2006, 11:54 PM
Jammer's Avatar
May I suggest some easy reading?
https://ls1tech.com/forums/advanced-engineering-tech/396086-camshaft-discussion-part-ii.html
https://ls1tech.com/forums/generation-iii-internal-engine/158394-camshaft-discussion-part-iii.html
Dont forget to party down with part I also.
Quick Reply: 408 folks please chime in!
