Flaring Question - LS1TECH
Flaring Question
Thread Tools Search this Thread
Old 10-22-2006, 01:59 PM   #1
MetallicaMatt's Avatar
Default Flaring Question
I had a question about how you should flare, or basically roll the ends of your tubing for a better seal, so the silicone connectors don't blow off
but, is there a tool I can buy to do this? Or is it really just easier to weld a beed around it?
thanks guys
also, is there a guideline to this?
like <8psi, no real need
>8psi, have the rolled edges
MetallicaMatt is offline   Reply With Quote
Old 10-22-2006, 02:04 PM   #2
It depends on the clamp and how tight you have them. Bead-rolling the pipe is a common thing to do for safty of it never blowing off. As for bead rollers, if your just doing a few pipes i would find a place that could do it for you.
Jake@EPP is offline   Reply With Quote
Old 10-22-2006, 02:07 PM   #3
smokinHawk's Avatar
i just welded a lip around my pipes, but im thinking a bead roller would work and look better.
smokinHawk is offline   Reply With Quote
Old 10-22-2006, 03:17 PM   #4
where do i get a bead roller? how much?
Old 10-23-2006, 08:46 PM   #5
so what kind of tool do i need?
Old 10-23-2006, 09:43 PM   #6
CHRISPY's Avatar
hairspray works great too
CHRISPY is offline   Reply With Quote
Old 10-24-2006, 10:02 AM   #7
TchargedLS1TA's Avatar
Normally bead rollers are found on (as in a part of) tubing benders.. There are some that you can use an impact with, but they are more of a headache than a help. You can weld a bead around it, just make sure the weld is smooth and there are no boogers to snag the silicone and tear it..
TchargedLS1TA is offline   Reply With Quote
Old 10-24-2006, 02:55 PM   #8
cool, thanks guys
Old 10-24-2006, 05:58 PM   #9
Go to a muffler shop, give them 10 bucks, have them beadroll the pipes. Done. Welding it too much of a PITA, in my opinion.
eviltwins is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
