procharger fan ?
Old 10-22-2006, 02:35 PM
ZDOG's Avatar
Default procharger fan ?
with the ac condenser removed is there enough room to push the radiator foreword and use the stock fans?
Old 10-22-2006, 03:43 PM
TS6
TS6's Avatar
Yes, I believe it has been done.
Old 10-22-2006, 04:04 PM
EPP
EPP's Avatar
You should have plenty of room if you move the bottom of the radiator into where the condensor was located. Bob
Old 10-22-2006, 10:16 PM
Cyborg's Avatar
Yes if you use the stock inlet hat, maybe, maybe (probably) not if you use a tubular custom inlet hat, which will net you upto an additional 100hp...but I'd always suggest trying the stock shroud & fans regardless.
