coughing up oil
Old 10-25-2006, 09:22 AM
SuperSlow02's Avatar
Default coughing up oil
My friend has a procharged car. And the other day after running her at the strip we noticed oil on the airbox, so we took it apart and there was oil inside the entire intake system. Its deffinently motor oil..so the chargers not leaking. The car still runs fine, no knocking or unusual ticks. You guys have any clue?
Old 10-25-2006, 10:35 AM
AVB
AVB's Avatar
You really ought to do a search cause you'll find this is discussed alot and often. But since I'm typing I'll at least tell you the issue is the PCV system not being designed for boost. Alot of ways to resolve which you should do a search for.
Arnel
Old 10-25-2006, 12:21 PM
damn lighten up, ive been looking through the boards for quite awhile and never once saw anything about that. But thank you for you help
Old 10-25-2006, 12:53 PM
JMBLOWNWS6's Avatar
Do a search on PCV setups for boosted cars
Old 10-25-2006, 06:27 PM
check and check. Guessing swap over to a catch can?
Quick Reply: coughing up oil
