Gmr Speed Turn Key Twin Turbo Winter Special!! Cant Miss This One!!
Suspended Sponsor
Its been awhile since we have had any kind of specials and posted in the sponsor sale section, so now we are going to make up for lost time
(Read carefully)
GMR SPEED TWIN TURBO, LONGBLOCK AND COMPLETE FUEL SYSTEM PACKAGE:
GMR SPEED TWIN TURBO STAGE 1 includes:
The retail on this kit installed and tuned is $9599.00 (Plus any upgrades to turbos and ceramic coating options)
KEEP READING THIS IS NOT THE SALE PRICING.....yet
GMR SPEED HIGH FLOW FUEL SYSTEM includes:
This is an option to our twin turbo package that usually sells for $1999.99 installed
GMR SPEED 364 CI TURBO LONG BLOCK includes :
This is a new engine package that we are offering for $5999 (This does not include installation. )
We have tuned this similar package to 724 RWHP and 740 RWTQ, with the only difference being we used an out of the box LS6 camshaft and a stock 6.0L crankshaft, so we have improved on the camshaft, worked the heads a little and added the strength of a forged crankshaft in this package.
Now for our winter promotion we are offering the GMR SPEED TWIN TURBO STAGE 1,GMR SPEED HIGH FLOW FUEL SYSTEM, and the GMR SPEED 364 CI TURBO LONG BLOCK INSTALLED and TUNEDfor $17,500. Usually these 3 packages together come to a total of $17,597 and DOES NOT include the installation of the engine, so we are basically installing your engine for free.
On top of this awsome deal we are also discounting turbo options and upgrades as well as fuel injector prices, THESE PRICES ARE ONLY VALID WHEN PURCHASED WITH THE TURBO/FUEL/ENGINE PACKAGE!!
Ceramic Coating to all turbo hot parts[Polished, black satin or gloss black finish]
Regular Price - $325
Package Price - $250
SAVE $75
Regular Price - $375
Package Price - $325
T-67 Journal bearing turbos
Regular Price - $550
Package Price - $500
T-67 Ball bearing turbos
Regular Price - $750
Package Price - $700
T-67 GTQ turbos
Regular Price - $1100
Package Price - 1050
T-70 Journal bearing turbos
Regular Price - $685
Package Price - $635
T-70 GTQ turbos
Regular Price- $1125
Sale Price -$1075
T-76 GTQ turbos
Regular Price - $1275
Sale Price - $1225
Precision 65 lb/hr High Impedance Fuel Injectors
Regular - $485.99
Package Price - $400
SAVE - $85.99
Precision 75 lb/hr Low Impedance Fuel Injectors
Regular - $489
Package price - $400
SAVE- $89
Precision 84 lb/hr Low Impedance Fuel Injectors
Regular - $489
SAVE - $89
Precision 95 lb/hr Low Impedance Fuel Injectors
Regular - $520
Package Price - $430
SAVE - $90
NOTE: An impedance covertor box is needed to run low impedance injectors on a stock PCM, we can provide an Acceleronics Convertor Box for $350 + installation [Regular $399].
For more information on our turbo kit or have any questions about this sale please visit the GMR SPEED TWIN TURBO WEBPAGE,call us at 1-866-899-4948 or email sales@gmrspeed.com
This sale is good until 12/24/2006 and all prices listed are only good if the whole package is purchased. Please PM or post any questions you may have.
(Read carefully)
- 2 Precision T-61 turbos [Turbos can be upgraded, keep reading and see below.]
- 2 44mm Tial waste gates
- 1 50mm Tial BOV
- Bar & PlateAir to Air Front Mount Intercooler
- T- 304 Stainless Steel tig welded manifolds
- T- 304 Stainless Steel Intercooler piping
- 4 Ply silicone with stainless steel t-clamps
- MSD Super Conductor spark plug wires
- DEI plug boot protectors
- NGK TR6 plugs
- All hardware & brackets
- Alternator relocation bracket
- Mandrel bent 3" y-pipe exiting to factory exhaust
- 3" downpipes
- 2 Walboro intank high flow fuel pumps
- - 8 Earls stainless steel feed line
- Aeromotive y-block, fuel rails, and pressure regulator
- All Earls AN fittings
- Professional installation Included
*Fuel Injectors NOT Included
- New GM 6.0L Iron Block
- Wiseco -25CC Turbo Pistons
- Wiseco Piston Rings
- Eagle H-Beam Connecting Rods w/L19 rod bolts
- Federal Mogul Rod and Main Bearings
- ARP Main Studs (Including ARP side bolts)
- Eagle 4340 Forged Steel Crankshaft
- Rollmaster Double Roller Heat Treated Adjustable Timing Chain
- GMR SPEED custom grind turbo camshaft [Specifications can be ground to customers requests.]
- ARP Head Studs
- GM MLS Head Gaskets
- Trickflow Hardened Pushrods
- New GM Lifters and Lifter Trays [Can be upgraded to Comp for $100]
- 317 casting 6.0L heads featuring:
- Total Engine Airflow (T.E.A.) Competition Multi Angle Valve Job
- .650" lift Dual Valve Springs w/ Titanium Retainers
- 72cc Combustion chamber - Professionally Blueprinted and Balanced
SAVE $75
SAVE $50 ON TURBO UPGRADES
T-61 Ball bearing turbos Regular Price - $375
T-67 GTQ turbos
T-70 GTQ turbos
Sale Price -$1075
T-76 GTQ turbos
Sale Price - $1225
FUEL INJECTORS (Pricing only good with package purchase.)
Regular - $485.99
SAVE - $85.99
Regular - $489
SAVE- $89
Regular - $489
SAVE - $89
Regular - $520
SAVE - $90
UMI PERFORMANCE TUBULAR K MEMBER AND A-ARM UPGRADE
While we have your motor out, this will be the best time to get rid of that heavy stock K-member and a-arms. Let us replace it with a quality setup from UMI PERFORMANCE. Price on this changeover is $1450, this price includes UMI Tubular K member, upper and lower control arms, and the labor to switch over steering rack, brake lines and struts.
Suspended Sponsor
I have had a couple requests asking if I would offer a sale on the single kit and motor package. I will do so just PM, email or call me with your request .
Suspended Sponsor
Originally Posted by burnham187
Damn, a little late for me, too bad I have already started my buildup as this looks like a mighty good offer.
Originally Posted by Leo@GMRSPEED
Its never too late to turn back
Suspended Sponsor
Unfortunately once the money is already spent and the parts are bought, then yes it is too late. Although, if you would part with the 95lb/hr injectors for $480 without the kit than I would consider this a good deal. Sorry but ive already purchased my turbo kit,etc so im looking for a good fuel system at this point.
chronic masturbator
all i have to say is WOW!!!! some people ask for a proven turn key package and WAMO gmrspeed has done it, some of you see 17k and say HOLY $hit thats alot of money but damn dude its worth it, top notch work and customer service so good that there are no words to describe, it im honestly shocked!!!!
sincerely
"the resident gmrspeed nut hugger"
sincerely
Suspended Sponsor
sincerely
sincerely
Suspended Sponsor
Originally Posted by jeffstar
Wow, rather amazing deal here. Curious, does the twin turbo system allow for AC or is that only the single kit? Do you have a sale on the single kit if so? Thanks!
The single kit does retain A/C and yes I can cut a deal on the single kit, shoot me a PM of your intentions and I can get quote together for ya.
-Leo
Suspended Sponsor
Originally Posted by topend
Will it pass the sniffer test??
We have not had anyone try to pass a sniffer test with this kit so I cannot say it has though I dont see why we couldnt make it so that it would pass.
Suspended Sponsor
uh oh ray going to the darkside???
Ray I defiantly want to work on retaining the A/C and would love to use your car to mach everything up, we can talk more Friday at the track or maybe ill swing by and we can go over some options
