Reasonable price on a used(500m) T70
Old 10-30-2006, 06:30 PM
TransAm6383's Avatar
Default Reasonable price on a used(500m) T70
Its a masterpower T-70** with a .68 exhaust...it has 500 miles on it. Do you think 450 is a reasonable offer for this turbo or is it worth more?..also..where could I get a .96 A/R housing for this turbo if I were to buy it.
Old 10-30-2006, 07:34 PM
BLWN1's Avatar
so is it a 70 or 76? I think the 70s could be bought for mid to upper $500s a while back..
Old 10-30-2006, 08:49 PM
HydroStream6's Avatar
I paid $525 I believe in the spring for mine... offer $450 and see what he says... $500 wouldn't be a bad deal though.
From my own personal expierience, you can use a Garret exhaust housing on MP turbos, but you cannot use MP housings on Garrett turbos...
Old 10-31-2006, 02:10 PM
kbracing96's Avatar
That funny, cus I'm running a MP .68 A/R housing on my garret T-60 right now
Old 10-31-2006, 03:26 PM
I tried doing the exact same thing and it would not fit. There was some clearance issues on the turbine wheel to housing... I guess YMMV.
Old 10-31-2006, 03:38 PM
SUPER DAVES Z's Avatar
I never had a problem running any exhaust housing on a MP turbo (just had to make sure it was a P-trim housing) but I guess if they had problems .......
Either way $450 is a good price. You can check turbomustangs.com and ebay for exhaust housings (found one for my old set-up for $50 shipped on ebay). I would ask why the guy is selling it and try and make sure it's in good shape before any money changes hands.
Good luck!!
Old 10-31-2006, 04:34 PM
yeah I just need to get a .96 TB housing...so any "p" trim t4 will work?
Old 10-31-2006, 06:01 PM
Correct... you'll most likely want an on-center with v-band exit.
Old 10-31-2006, 07:57 PM
KraZy's Avatar
I'm running a MPT70 w/ .96housing - worked great. I'm switching to 6.0 manifolds from stock ones.
Contact Jose at ForcedInductions he can get the housing you need.
Old 10-31-2006, 08:49 PM
I Think you ment TANG. with V-band. However I have a half PT* half custom setup. I have their headers and cross over all the way to the sway bar. Then from there the turbo goes up to the batteries location instead of the front of the engine.
