Venting crankcase pressure
Old 11-06-2006, 12:55 AM
BoostBandit's Avatar
Default Venting crankcase pressure
I was just wondering what more I could do to vent more crankcase pressure from my motor other than the off the front of the passenger valve cover through the solenoid from the sts kit which I have ran to a catch can, And I also replaced the oil cap with a OEM replacement breather. I was hoping to do more with out having to pull the valve covers and weld. Thanks guys
Old 11-06-2006, 01:02 AM
Quickin's Avatar
Put a breather on the drivers side valve cover too, where the PCV plug is in the rear of the valve cover.
Old 11-06-2006, 01:11 AM
thanks alot for the help
Old 12-23-2006, 05:30 PM
Tiger2o69's Avatar
Are you just t-ing into that pcv line or removing it?
Old 12-24-2006, 08:04 AM
OUTLAWZ RACING's Avatar
I ran all the lines off the valve covers to a catch can with a air filter on top then I ran the sts switch valve of a nother fitting to the intake. Also its a good that u took of the return line for the turbo off the top of he motor way toomuch oil up there.
Quick Reply: Venting crankcase pressure
