over heating procharged 408... my solution.. hope it works
7 Second Club
heres my plan of attack... i just ordered a radiator from summit p# GRI-55241-x 27.5 wide 15.5 high and 3'' thick...
along with a 9'' spal fan from bob @ www.exoticperformanceplus.com
the radiator will stand str8 up after some cutting and welding inside the engine compartment.
im going to reuse the "stock" ATI fan that came with my ATI kit and the shroud...
cut out a 9'' hole and mount the fan and the top of the driver side of the RAD... both of these fans will be hard wired into my toggle switches...
im hoping to keep my temps under 190 while street driving... thats why the new radiator....
hopefully in 2 weeks ill have my stuff back up and running.
Originally Posted by ty_ty13
i want more clearance so i dont want to use the stockers... also i want to leave the fans on when the car is off cause its a race car...
? You can just set them to run (even with the car off) with VCM controls.... You can set them to automatically run when the car is off until a preset temp is reached as well... It just seems like you are doing more work only to have to do even more down the road.
TECH Cry Baby BOSS APPROVED!
Originally Posted by 00TAProject
Also not to mention the weight that you will be adding with that radiator and fluids......
Not a big penalty to pay if it keeps your car cool. I do not know if you ever had a car that overheats, but I tell you it is not fun.
7 Second Club
i still like having the fans on toggle so i can turn them on off whenever i like... and the added weight im not too woried about as long as i can drive the car in the middle of the summer and stick my foot in and out of it as i like and the temps not go crazy...
