New T76mm Turbocharger on it's way to mi casa!
Old 11-14-2006, 03:14 PM
mightyquickz28's Avatar
Default New T76mm Turbocharger on it's way to mi casa!
I'm looking forward to the upcoming battle of getting this Turbo installed and tuned. I've needed a new adversary ever since getting divorced from Devilores. This should provide plenty of Oomph since Forced Inductions said this turbo can support up to 1,000 Hp. I'm shooting for a more modest 600 rwhp since this is a street car. I'll post pictures and testimonials as things progress.
Wish me bloody knuckles
Old 11-14-2006, 03:18 PM
LS1TECH Sponsor
DrTurbo's Avatar
We have you a TC76 on order already. . We will have an ETA from T-netics tomm morning.
Old 11-29-2006, 08:56 AM
Scenario: It's 9:00am here in East Chatham, New York. I'm upstairs and I hear the dogs (Harley, the minpin and Rosie, the Long Hair Jack Russell) start barking their heads off. I'm thinking, "stupid dogs..They bark anytime a leaf blows across the yard..sigh..", and I finish brushing my teeth (I telecommute from here to Houston, working all day in my pajamas..don't be h8tin', lol) and then walk down to the kitchen to pour a cup of coffee. The coffee maker is beside the glass back door and out of the corner of my eye, I see a white box on the back porch.... I let out an appropriate Texas WoooHooo! and grab the box, put it on the dining table and open her up...
http://www.taekwondoplus.org/z28/Turbo/Turbo007.jpg
http://www.taekwondoplus.org/z28/Turbo/Turbo009.jpg
http://www.taekwondoplus.org/z28/Turbo/Turbo010.jpg
Now just waiting on the (already ordered/paid for) TS-38 Wastegate and Mototron 60# Fuel injectors. They should be here later today or tomorrow. I can't really start just yet. I still have lots to order but I'm well on the road and already $2,000 plus into it just with this much. I've been reading various "Forced Induction" forums and I've been learning a lot. One thing that is for certain, the STS Turbos (rear mounted, near the differential), in a lot of cases, are Kicking some serious *** with 9 second passes on forged lower ends. 700 plus hp in quite a few cases. Some of the traditional located Turbo LT1's are using everything under the sun for exhaust manifolds. Stock, Logs, Headers (Homebuilt and Pro built). The arguments for using logs is compelling. They are easy (but homely, but then again, so am I and I work REAL well!) and some log designed cars are putting out over 1,000 HP.
I'll keep updating this as I get parts and or progress.
David K. Wilson
'94 Z28 383 LT1 A4 3.42
'96 Z28 383 LT1 M6 4.10 (T76 Turbo being installed)
Old 11-29-2006, 08:59 AM
LS1TECH Sponsor
DrTurbo's Avatar
Glad you got it and glad we could help!!! The gate is also on its way...should see it shortly. The TC76 really is a killer turbo for the money.
Old 11-29-2006, 09:06 AM
Jose, thanks so much for the great customer support and great prices! You'll be seeing my caller ID on your phone a lot in the coming months
Old 11-29-2006, 09:14 AM
LS1TECH Sponsor
DrTurbo's Avatar
I'm not Jose, but I'll relay that to him.......
I'm not as ugly as him.......and since he'll see this post maybe today..... ------>
Old 11-29-2006, 01:15 PM
frcefed98's Avatar
post up your results with your TC76 when you get that far.....so far I haven't seen too many people post up what they are seeing with the TC76 other than spool time and what not. I hope to post up some good #'s with mine as soon as I figure out why it won't boost past 9psi.
J
Old 11-29-2006, 04:13 PM
stevieturbo's Avatar
What sort of physical size is their 76mm ??
Old 11-29-2006, 04:37 PM
frcefed98's Avatar
T4 flanged, and should be demensionally the same size as a T67,70 etc...
weight is about 25lbs.
2.5 compressor outlet, 4 inch compressor inlet
3 in Vband turbine outlet.
Compact, fast spooling and *should* support near 1K on 346 cubes.
Old 11-29-2006, 05:10 PM
I'm thinking for an engine less than half that size lol. Was on a ITS T70 before it dropped a valve....
The Turbonetics warranty would have came in handy there.
Old 11-29-2006, 05:28 PM
OneMeanZ's Avatar
How do you support the turbo? Or is the crossover suppose to be strong enought to hold the turbo up there?
Old 11-29-2006, 06:07 PM
LS1TECH Sponsor
DrTurbo's Avatar
Yes its a compact unit and the warranty would have helped...lol
Old 11-29-2006, 06:12 PM
CHRISPY's Avatar
So this turbo is the same size externally as a T67? What AR did you go with and is it on center or Tang?
Old 11-29-2006, 06:13 PM
LS1TECH Sponsor
DrTurbo's Avatar
His unit is a tang, and they are very close to the T67.
Old 11-29-2006, 06:29 PM
frcefed98's Avatar
And is very affordable for what you get, near 1k hp potential, 1 yr unconditional warranty...
One mean, you could run a brace for the turbo, but its not that "heavy" so to speak. My TC76 is supported soley off the crossover and truck manifolds(which are cast and very strong) I use to run my Gt42 that way too, and that thing weighed in at 45lbs. I should've had it supported or braced though.
You could also run a flex joint in your crossover for added flex if you are running a big turbo.
Old 11-30-2006, 02:51 PM
More dog barking today...
http://www.taekwondoplus.org/z28/Turbo/Turbo011.jpg
http://www.taekwondoplus.org/z28/Turbo/Turbo012.jpg
http://www.taekwondoplus.org/z28/Turbo/Turbo013.jpg
THis is the TurboSmart 38 Wastegate that Jose at Forced Inductions recommended to go with the TC76 w/MPS wheel.
THanks Forced Induction..
Hopefully, the dogs will bark tomorrow to indicate the 60# Mototrons are here
Old 12-04-2006, 12:44 PM
The Mototron 60 pounders arrived today.
http://www.taekwondoplus.org/z28/Turbo/Mototron.jpg
I got these used from a guy on the LT1 edit list for $400 including shipping. They have about 500 miles on them. They are flow matched by Racetronics.
Another step towards Nirvana!
David K. Wilson
Old 12-04-2006, 12:55 PM
LS1TECH Sponsor
DrTurbo's Avatar
No problem....if you need anything else give us a shout.
Old 12-05-2006, 09:55 AM
Ordered the Hot Parts kit a few minutes ago. Stainless steel log style. Half inch plasma cut header flanges, all the V bands/clamps, etc. The T76mm will be mounted where the stock Air Pump is usually located. Part of the weight of the Turbo will be supported by the drivers side T4 flange and additional support is from a quarter inch bar stock from the T4 flange to the header flange. The kit will have provisions for 3 O2 bungs. Two for the stock narrow band and one for my Innovate wideband O2 sensor. It'll be awhile since this is a custom kit. The projected delivery date is end of Jan to middle of Feb. That's okay. It's snowing right now so it's not like I could do anything if it were a shelf item.
Old 12-05-2006, 10:06 AM
datsbad's Avatar
what kind of cost to you have into this so far ?
Quick Reply: New T76mm Turbocharger on it's way to mi casa!
