Clipped Wheel Thread
Old 11-14-2006, 09:22 PM
ChrisUlrich's Avatar
Default A Clipped Wheel...?
What does this phrase mean? haha
My buddy in his S4 took his two stock turbos and clipped the wheels. What does he mean by that?
Old 11-15-2006, 08:18 AM
No one?
Old 11-15-2006, 08:40 AM
trtturbo's Avatar
A qualified person can clip the turbine wheel blades and somewhat effect how it spools. We have had it done a couple of times and you can feel the difference. You can also lighten the turbine wheel too. I have heard mixed results on that though.
Old 11-15-2006, 08:46 AM
So it just helps it spool quicker... not make more power?
What's actually happening to the wheel though?
Old 11-15-2006, 09:07 AM
LS1TECH Sponsor
DrTurbo's Avatar
Jose and Jason do clippings for alot of our diesel units. Clipping drops efficiency of the turbine down and slows the spool up, but does relieve backpressure. That is the main purpose for backcuts.
Old 11-15-2006, 09:15 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
What is changed?
Old 11-15-2006, 09:53 AM
LS1TECH Sponsor
DrTurbo's Avatar
What is changed?
The turbine wheel is machined on a CNC down by back cutting the fins 10 to 30 degrees. Then precision balancing is needed..and then that is it. The problem is knowing how much and where to cut the material out.....its a black art for sure. I have no idea how to do it, but I know the process...hehe
Old 11-15-2006, 05:54 PM
Excuse my ignorance... why would you want this again?
Why would a car like the S4 want it?
Old 11-15-2006, 06:10 PM
BIG BAD BLACKSS's Avatar
Cause ricers like spending big $ on stuff they can brag about even though it doesnt make them any faster???
Old 11-15-2006, 06:48 PM
JASON11WS6's Avatar
To funny, only cause its so true.
Old 11-15-2006, 07:45 PM
flynbludream's Avatar
Old 11-15-2006, 08:15 PM
LS1TECH Sponsor
DrTurbo's Avatar
An S4 uses fairly small turbos that become inefficienct and backpressure starts to rise fast with boost. So to counter the back pressure you have it clipped.
Old 11-15-2006, 08:31 PM
Snyper's Avatar
wouldnt the clipped wheel make it spool faster since it would be lighter?
Old 11-15-2006, 08:40 PM
LS1TECH Sponsor
DrTurbo's Avatar
You would think, but no. The way Jose and Jason explained it to me was when the turbine is clipped you are now bypassing more air around the turbine blade face, so less actual push on the blade, which effects it greater then weight loss does, which is very minimal anyhow.
Old 11-16-2006, 06:38 AM
To much backpressure is bad why?
Not enough back pressure is bad why?
Old 11-16-2006, 07:02 AM
chuntington101's Avatar
too much is bad cos it chokes the engine. you normally want back presure to be below 2-1 (ie twice you boost presure). if you could run 100% effient then you would be at 1-1, but you cant! lol i think after 2-1 you start to loose power.
why is to little bad?? well cos you need some back presure to turn the turbo! if you had none then why would the turbo spin? this is what the weastgate is for, to keep the backpresure at the levels that give you the boost you want!
i dont like clipped wheels. you should have to run them if you have the right combination of hot and cold side.
is there not a company that will do a hybrid turbo for them?? maybe a bit bigger on the exhaust side???
thanks Chris.
Old 11-16-2006, 04:01 PM
thanks Chris.
What would be the downfall on a poorly clipped wheel?
Old 11-16-2006, 06:45 PM
JASON11WS6's Avatar
I mentioned this tread to a friend of mine and he said that this stuff it for real. Although the one car he seen it done on was a Vortech Supercharged car. He said the guy put in new lighter ball bearings and clipped the wheel. Said the car was way quicker after that and a tranny rebuild. The MPH was their to suggest it was pulling more power as well. I want to say a half second and maybe 5mph. Just what i heard though.
Old 11-16-2006, 07:01 PM
Turbo2.4Liter's Avatar
a clipped turbine wheel and ball bearings with a vortec sc?
Old 11-16-2006, 07:05 PM
frcefed98's Avatar
cuz his friend told him, thats why
This one is over
Quick Reply: Clipped Wheel Thread
