Looking for guys who make 900+rwhp with turbo: block opinions
Old 11-19-2006, 08:23 PM
7 Second Club
Phil99vette's Avatar
Default Looking for guys who make 900+rwhp with turbo: block opinions
If you guys were to rebuild your motor which block and crank setup would you go with? Blockhard? Stock crank? Billet Main Caps?
Old 11-19-2006, 08:33 PM
Jake@EPP's Avatar
While its possible on the aluminum block, if you want ultimate reliability at this power level , a iron block is usualy reccomended. Some have made 1k on the stock crank, usualy people go with a stroker either a 383 or 408 from either eagle or callies.
Old 11-19-2006, 08:50 PM
7 Second Club
Whats the max RPM or piston speed you can use with a 4" or 4.125" stroke?
Old 11-19-2006, 09:25 PM
SSilverSSurfer's Avatar
tired of your motor already? or this build for someone else
Old 11-20-2006, 01:24 PM
7 Second Club
New build all together.... My car just went 10.1 @ 145 on a 200 shot with alot more on the table....
Old 11-20-2006, 01:50 PM
SiL3NtXWS6's Avatar
damn.... 145 is booking it.
Old 11-20-2006, 02:05 PM
7 Second Club
Its got 3-6mph left in it!
Old 11-20-2006, 02:31 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
95% of the big boys will reccomend iron blocks for that power goal Phil. I think Mike Brown might be the only holdout to go LS2. I'm on the fence, but I have not put that many passes on my shortblock yet.
Old 11-20-2006, 04:48 PM
KHShapiro's Avatar
i have an MID block but you can also get a dry sleeve ls2 block, and while some builders dont like to use them non have given me any examples of any (RED) comming apart. the most is a little pushing which from my understanding on 99% of them that had that problem it was fixed with a little copper coating and retq of the heads, not to mention higher hp fi engines do that a little.
Talk to Steve at RED his blocks are hold tons of HP and TQ and oh yeah he is a sponsor so maybe he will chime in, if he sees the thread.
Old 11-20-2006, 08:42 PM
MIGHTYMOUSE's Avatar
i havent had any problems with my ls2 block so that makes me happy with the change from iron to get the weight savings.
Old 11-20-2006, 08:49 PM
02SSLE's Avatar
iron here
Old 11-20-2006, 10:28 PM
LTLHOMER's Avatar
Dunno how much power I made but it was on a stock ls1 block.
If I were doing it again, I'd get the GMPP block and be done with it...big bore short stroke and add boost. Drysump though! lol Unless of course that block has a better oiling setup to use the factory style pumps.
Old 11-20-2006, 10:47 PM
FormulaFire's Avatar
I'm a big fan of the LS2. Just me. They have soo many options now and coming out it's hard to choose.
Old 11-21-2006, 12:39 AM
LS2Camaro's Avatar
Forged bottom End LS2 here. I have not heard of anyone breaking the LS2 Block even on Boost. I could be wrong??
Old 11-21-2006, 05:16 AM
NA$TY-TA's Avatar
Iron here.... When i do it again id like to go with an Alum. LS2. That extra 90 lbs on the nose is hard to get rid of.... Yes the Iron is nice for strength.... but man does it hold the heat more under the hood....
Old 11-21-2006, 06:15 AM
2001WS6Vert's Avatar
We're going aluminum in the race car. Somebody needs to really push the aluminum so we'll all know where the limit is. We should be light with an LS2 and a glide. If your really worried you could look at the Warhawk block.
Fireball's Avatar
I went with a LS2 with good internals
Based on my math, the new combo should be ~1300 FWHP
Old 11-21-2006, 08:50 AM
LS1Tech Co-Founder
I've made 867rwhp with a 2001 LS6 block that is bored 3.910.
If I were doing up another shortie, I'd be doing an LS2 + forged crank to follow the path trailblazed by Mike Brown and Steve Turley. Mike has been flogging an LS2 down into the 8.4's.
The issue that is discussed by engine builders is called 'creep' or for us layman, block expansion. The bores can get distorted due to major boost and heat, and they don't go back to their original shape. I wonder what Mike's response would be to this issue. And the other issue is that iron blocks won't expand or distort when it comes to the deck surfaces either.
Old 11-21-2006, 09:00 AM
JMBLOWNWS6's Avatar
I would talk to this guy https://ls1tech.com/forums/showpost....0&postcount=47
Or W2W.
Old 11-21-2006, 11:55 AM
427's Avatar
This question is tough to answer, its interesting to read the reply's so far. I have some LS2 info gathered from a engine we just took apart that had been raced hard and maintained well through its life. The pics attached(I hope they are attached!) will show you some cylinder and block damage that seems to be the norm when dealing with the aluminum block. The deck cracks also show up on high hp iron blocks eventually, but we have not been able to disect enough engines to be hard and fast about facts. This paticular block is cracked in 7 places and was performing fine.
The cylinder shot shows the "smoky" look of the walls. I believe this is caused by the wall flexing under load, not staying round. This would cause some blow-by and lost power, this is worse in aluminum blocks we see.
You will also notice the lack of a defined stop point for the top ring, it should be 360 degree's around the bores top edge, but it changes pattern near the head bolts showing that the block is flexing from the head bolt load.
At 1200+ flywheel hp I would still use iron block, but the aftermarket blocks may change that. Who is going to be the first to push one to find the limit????
Kurt
Attached Thumbnails Looking for guys who make 900+rwhp with turbo: block opinions-2006_1121blockls20001.jpg   Looking for guys who make 900+rwhp with turbo: block opinions-2006_1121blockls20002.jpg
Quick Reply: Looking for guys who make 900+rwhp with turbo: block opinions
