How Did You Obtain your Desired Compression?
Old 11-22-2006, 06:23 AM
hashtagBMW
Speed Density's Avatar
Default How Did You Obtain your Desired Compression?
Just trying to get a nice little information thread going on ways to seek SCR.
So, what steps did you take to acheive a boost ready SCR? What was that SCR? What were the goals for that desired SCR?
Some things to list:
Heads
Pistons
Gaskets
Power Adder
And Last your location!
Tony.
Old 11-22-2006, 06:29 AM
Frost's Avatar
Big(ger) chambered ported factory heads
-cc pistons (this is the variable changed to get my desired CR but I forget the dish volume)
GM MLS head gasket
single front-mount P76GTS turbo
I'm at about 8.6:1. My goal for this setup is 700RWHP on pump gas and methanol with the M6 before moving to the th400. I used an online calculator like this one to figure SCR: http://www.csgnetwork.com/compcalc.html
Old 11-22-2006, 11:11 AM
Dumb Ass Vette Moderator
ls1290's Avatar
First selected the desired heads. Then based on the chamber volume, ordered dish pistons with the corresponding volume to meet the end static compression ration.
74cd TEA Stage III 317 heads, -15cc diamond pistons, 402 stroker, yeilds a 9.2:1 static compression ratio.
Keith
Old 11-22-2006, 01:04 PM
Fire67's Avatar
Bigger combustion chambered stock heads ported to desired cc's
Flat top pistons with valve reliefs
9.0 :1 with Cometic gaskets
Old 11-22-2006, 02:04 PM
stevieturbo's Avatar
Pretty much stock sized chambers ( as Edelbrock supply/CNC them at 67cc ), stock GM MLS gaskets. Mine is pretty much all in the piston dish. -25cc
9.7:1
Old 11-22-2006, 02:41 PM
trey04gto's Avatar
317 castings CNC'd to 76cc, GM MLS gaskets, -4.00cc piston relief
9.2:1
Old 11-22-2006, 03:45 PM
pwrtrip75's Avatar
5.3L block and 6.0L heads.....8.6:1 compression.
Old 11-22-2006, 04:40 PM
hashtagBMW
Cool!
Keep it up guys
Tony.
Old 11-22-2006, 05:42 PM
High on diesel fumes
thunder550's Avatar
74cc heads
-28cc pistons
.03" head gaskets
8.9 to 9.0:1
Diamond has an awesome CR calculator
http://www.diamondracing.net/cocalc.htm
Old 11-24-2006, 07:08 PM
hashtagBMW
Bumpity.
Tony.
Old 11-24-2006, 07:30 PM
lethal93ta's Avatar
4.030 bore
3.75 stroke
-31cc pistons
58cc heads
.03 head gaskets
9.0:1
Quick Reply: How Did You Obtain your Desired Compression?
