pics of BBC in f/body
Old 11-23-2006, 05:23 PM
1969CAMARO's Avatar
Default pics of BBC in f/body
please, anybody
Old 11-23-2006, 05:24 PM
1969CAMARO's Avatar
oh yea w/ supercharger, sorry
Old 11-23-2006, 05:38 PM
GrahamHill's Avatar
http://www.memphisracingscene.com/pp...ry.php?cat=763
No blower though. 502 block I believe
Old 11-23-2006, 08:59 PM
LS1Tech Sponsor
Brady's Avatar
http://teamprickracing.com/firebird4/
557" bbc with an F3 on methanol.
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old 11-23-2006, 09:27 PM
BLWN1's Avatar
^ you officially suck.....
Old 11-23-2006, 09:30 PM
GrahamHill's Avatar
How much power could that make?
Old 11-23-2006, 09:59 PM
LS1Tech Sponsor
Brady's Avatar
who knows what it could make, but it did make 2300 on a blowthrough alky carb setup.. should pick up some on EFI.
__________________
2016 Z07 Carbon
Old 11-24-2006, 03:58 AM
red90cobra's Avatar
Old 11-24-2006, 06:20 AM
1969CAMARO's Avatar
ok, will the supercharger need to be mounted in front of the eng, why not dr side, and what about hood clearance
Old 11-24-2006, 06:25 AM
chuntington101's Avatar
do i count 20 injectors????
four in the elbow and two per cylinder!
Chris.
Old 11-24-2006, 08:05 AM
LS1Tech Sponsor
Brady's Avatar
22- 160# injectors (6 in the elbow) with a base fuel pressure of 70#. Belt drive Waterman fuel pump. I'm plumbing the fuel system today, I'll post up a pic later.
If you're putting a bbc in a 4th gen, reverse rotation is the way to go. A couple years ago (before reverse rotation?) I tried a conventional drivers side mount F3 on a 540, and it would require major major surgery to the strut tower, and posibly even get into the the tire. Not to say you couldn't have custom brackets made, but the reverse rotation stuff fits so why bother. The blower (much to my suprise) clears the VFN 4" WS6 hood.
I just found a pic.
__________________
2016 Z07 Carbon
Old 11-24-2006, 06:24 PM
1969CAMARO's Avatar
so the this set up that is above will work, and what , thats an F2, looks like alot of blower, im only running a 402, need about 12-15 lbs boost ??? what do you reccomend
Old 11-24-2006, 06:26 PM
1969CAMARO's Avatar
what about a blow thru , carb set up
Old 11-24-2006, 06:46 PM
Ls1Bait's Avatar
That motor is Crazy
Old 11-24-2006, 07:54 PM
LS1Tech Sponsor
Brady's Avatar
an F2 would probably fit a little better and be more than enough blower. We ran an F2 last year and went 5.30's in the 1/8th w/a 360" motor.
__________________
2016 Z07 Carbon
Old 11-24-2006, 07:59 PM
1969CAMARO's Avatar
is F2 is smaller than the F1 and where will it mount, on dr side??? and what are the pros and cons of a blow thru...
Old 11-24-2006, 08:14 PM
LS1Tech Sponsor
Brady's Avatar
F2 is bigger than F1. you could mount it either conventionally or reverse rotation. I don't have much experience w/blow through. I'm an EFI guy.
www.procharger.com/models.shtml for more procharger info.
__________________
2016 Z07 Carbon
Old 11-24-2006, 08:50 PM
Got Me SOM's Avatar
question do you have to cut the cowl to fit the BBC? anyone see the pics of madmans car on teamprickracing with the f3 mounted in the center. looks awesome.
Old 11-25-2006, 07:54 AM
1969CAMARO's Avatar
ok, so no pics of a blow thru on a bbc in a 4th gen
Old 11-28-2006, 06:59 AM
so do you stage each injector?? that a hell of a lot of injectors!!
and with the 6 in the elbow i bet the intake temps are really really low!
thanks Chris.
Quick Reply: pics of BBC in f/body
