Thinking of FI my stroker.
Old 11-27-2006, 06:37 PM
jeremym's Avatar
Default Thinking of FI my stroker.
I have a 414 stroker and was thinking of a s/c or a turbo. I have a flat top piston w/ 2cc. If I just change my heads to a stock 6.0 317 cast what would my comp be and could I do a s/c? I am trying to do this w/out tearing the motor apart just to change the pistons.
Old 11-27-2006, 07:13 PM
TINKRD's Avatar
Jeremy, the cost of swapping your setup over to makeing REAL HP is going to cost you $$$
Sure all you could do now is swap heads, but you wouldnt be able to make alot of boost b/c of compression. what's the point of spending 3-5K if you can only run 5-10lbs of boost??
IMO, if you're going to take the FI plunge, do it right. you'll want new pistons/rings/heads and then you'll need to upgrade your entire fuel system to support the new power.
This is one reason why i was on bottle for so long. I told myself that i didnt want to go FI and make the same HP(710HP on the bottle) or just a little more HP. If i was going to do it, i'd go for a BIG setup.
Do it once and do it right.
LSs1Power's Avatar
You compression is going to be on the high side... U might get away with 5-7psi from a Procharger.
Old 11-27-2006, 07:20 PM
TINKRD's Avatar
by using your current piston and 317 casting heads your static compression will still be around ~10.5:1
Old 11-27-2006, 07:27 PM
jeremym's Avatar
I could do a procharger around that comp. Even at low boost I should make good power.
Old 11-27-2006, 07:30 PM
LSs1Power's Avatar
On that motor and compression a D-1SC can supply you with enough air up to 750rwhp. If you dont have an A/C and plan to change the pistons in the future then I would look at starting with a larger blower such as F1-A or F1-C.
Good luck.
Old 11-27-2006, 07:53 PM
jeremym's Avatar
Good luck.
Thanks. Back to the drawing board. HP is more addicting than crack hahahahaha
Old 11-27-2006, 07:55 PM
TINKRD's Avatar
more expensive too!
Old 11-27-2006, 08:13 PM
LSs1Power's Avatar
more expensive too!
But once you go BOOST, there is nooo coming back
Old 11-27-2006, 08:17 PM
TINKRD's Avatar
oh i know. i'm building my setup right now.
Old 11-29-2006, 05:06 AM
EPP
EPP's Avatar
With 10.5/1 compression, a ProCharger and 93 octane will give you quite a bit of boost before you have to worry about detonation. Bob
Old 11-29-2006, 07:55 AM
Silver Bullet 98's Avatar
im gonna go with GT55 for the block?
Old 11-29-2006, 07:58 AM
V6 Bird's Avatar
Then you'll have more excuses then you do now about getting beat...eheh
Old 11-29-2006, 08:07 AM
TINKRD's Avatar
Old 11-29-2006, 08:17 AM
V6 Bird's Avatar
I think he is playing Hollywood squares on you..(tic tac toe)
Old 11-29-2006, 06:51 PM
jeremym's Avatar
What do you mean? Who have I lost too? I have only lost twice with my set up. One was a 522ci stroker RSI viper and I lost by 1 car and that was motor to motor, and the other was a N2O car with me on motor and him on N2O.
Old 11-29-2006, 08:47 PM
is that a gt55 in that bag?
Old 11-30-2006, 07:21 AM
TINKRD's Avatar
oh i thought you were trying to ask ask if my block (motor) was going to be a GT55.
i was like WTF?
gt47-88
Old 11-30-2006, 07:26 AM
V6 Bird's Avatar
You have to race people to actually win or lose
On the street its anything goes...Spray, NA, FI, etc....Cant complain when you bring a knife (NA car) to a gun fight.
You've had enough tuning issues as it is, pull the pistons and swap em. move to a 6.0 head ( I have some that will outflow what you got on your car by a huge margin) and put it back together. Put you a custom kit on the car with a 91.5mm Thumper in the gril and drive the **** out of it. Please dont take my advice. My car is still in pieces.
Old 11-30-2006, 08:01 AM
TINKRD's Avatar
you selling those heads?
i'm thinking of going with some ported L92 w/ a carb intake to match....but still just thinking about it. lots more research to do.
Quick Reply: Thinking of FI my stroker.
