Magnuson F-body - new dyno results
Old 11-28-2006, 06:35 AM
Ed @ Late Model Speed's Avatar
Default Magnuson F-body - new dyno results
I'm still installing the I/C kit, and should have it finished soon, but in the meantime, we were doing a little dyno work yesterday on the non- I/C car in my sig. Since this engine has ported heads, and lower comp(10.0:1) we decided to install a smaller pulley, and get a little more boost out of it.
We are now seeing a solid 7 PSI and the new numbers are 467RWHP/453RWTQ!
That was better than I expected, the I/C kit should easily make 500RWHP
More info to come soon,
Ed
Old 11-28-2006, 07:19 AM
KraZy's Avatar
Awesome!!
Old 11-28-2006, 08:15 AM
RealQuick's Avatar
Ed
Excellent #'s!
Old 11-28-2006, 05:05 PM
camarokid94's Avatar
Graph ?
Old 11-28-2006, 09:12 PM
sbcgenII's Avatar
what's the torque like in the 2k-2.5k?
Old 11-29-2006, 12:57 PM
Here is a copy of the dyno graph comparing the 5PSI run to the 7PSI run.
Let me know if I can answer any questions,
Ed
Old 11-29-2006, 06:45 PM
1FST99Z's Avatar
what is the limits of this blower as far as PSI is concerned, and HP. I am running a 408 and I am looking at going this route.
thanks
Old 11-29-2006, 07:47 PM
TopRPM's Avatar
That is badass.... I wish I had the cash to get one of these!!!
Old 11-29-2006, 07:50 PM
quicksilverado's Avatar
thanks
The 112 will not support a 408. The 122HH will do the trick.
Old 11-30-2006, 10:21 AM
I agree, the 122 would be needed for bigger engines. It will need a little more height, but nothing major.
Ed
Old 11-30-2006, 11:48 AM
DanZ28's Avatar
Will the 122IC support 700 RWHP on stock cubes? What is the max PSI? Also, any updates on the fitment of the IC model?
Thanks,
Dan
Old 11-30-2006, 01:58 PM
HioSSilver's Avatar
I would like to no more on the 122 also.
Old 12-04-2006, 10:43 AM
speedfreak440's Avatar
Still waiting on results of the I/C kit, keep up the good work.
Old 12-04-2006, 01:39 PM
farnoush's Avatar
NIIICCE....when will someone make a kit with a whipple
Old 12-04-2006, 01:51 PM
Moderator
jimmyblue's Avatar
Is this the holy grail, a no-hack-the-cowl Magnusson?
Or do you have to chop?
Old 12-04-2006, 07:34 PM
Ling_650vette's Avatar
On how he got it to fit -
Originally Posted by Ed @ LMS
The kit does require minor cutting of the cowl, but only on the lower part(close to the engine) The Late Model Speed install kit includes a template for making the cut, and a pre-formed panel that needs to be tack welded in place. The enitre cut area is about 3"x11" , and nothing needs to be re-located. The hood does need a little bit removed from the inner structure, but not a very big piece. I actually cut mine out way to big! some of the different hoods out there might not even need that, mine is the standard flat Z28 hood, but an SS hood, or Ram Air hood may have enough clearence already.
The entire subframe is lowered, much like a 4x4 lift kit, which allows the use of factory motor mounts, sway bars, suspension,etc. The nice thing is, that factory ride height, and alignment specs stay the same. The production kits will be intercooled, but my prototype in the pics is not.
Quit teasin us Ed! lol
Keep up the great work
Old 02-25-2007, 04:42 PM
Orange Krush's Avatar
Cool
Ditto!
Old 02-25-2007, 05:11 PM
99Z28LS1's Avatar
thats gonna be some awesome numbers, goodluck ED
Old 02-27-2007, 12:01 AM
94 slow's Avatar
ED,
Do you have the numbers with the I/C running 7 p.s.i.?
Old 02-27-2007, 09:04 AM
CALL911's Avatar
Even though running an I/C will end up giving you more power (since you can safely run more boost and timing without detonation), you probably won't see much of any increase on the dyno since your car won't have the oncoming air that it would at 60+MPH. Someone feel free to correct me if I am incorrect in my logic here.
Ed
Quick Reply: Magnuson F-body - new dyno results
